Unable To View 1080p !!
Discussion in 'Plasma TVs Forum' started by HDPio, Jan 16, 2008.
  1. HDPio
    HDPio
    On my 507xd i cannot output 1080p via component or vga? Why is this? 720p and 1080i work fine but not 1080p.
    What on earth's the problem :thumbsdow
  2. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    It doesn't accept 1080p over those connections
  3. trodat
    trodat
    Dec 4, 2007
    69
    +5
    The 507XD cant display 1080p so leave the settings at 720p or 1080i!!!
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    It can display it via HDMI can't it? Scaled down 1080p looks nicer than 1080i or 720p scaled up.
  5. trodat
    trodat
    Dec 4, 2007
    69
    +5
    maybe it can then. As for the picture quality it depends on the player being used. If its a cheap DVD scaling to 1080p and then downscaled by the screen i wouldn't bother.
  6. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Indeed, I was thinking native 1080p content.
  7. vyogee
    vyogee
    Oct 8, 2007
    81
    Penang, Malaysia
    +22
    All,
    527xd will only receive 1080p/24Hz over HDMI. It will not receive 1080p/50Hz or 60Hz over HDMI as well. Highest resolution through component is 1080i/720p.
    XBox 360 will output 1080p/50Hz over component and the XBox 360 Elite outputs 1080p/50Hz over HDMI.
    The 8G Pioneers however accept 1080p/24Hz, 50Hz and 60Hz...
    You might need to upgrade if you want it over [email protected]
  8. HDPio
    HDPio
    I have a 507XD btw. And how can i change it to 50Hz? Because i see no settings about the hertz !
  9. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    The xbox outputs 1080p/50 if it's 50Hz content (R2 DVD basically)
    it outputs 1080p/60 if it's games or HD DVD
    Either way, sounds like your screen won't accept it
