Unable to change transponder frequency
coolideas
Hi guys, hope you can help. I need to change the transponder settings but for some reason the TV won't accept them saying they are not within the range! It's not me making them up it's the Irish Saorview. They want me to change from 25000 to 24.5!
noiseboy72
Sorry, what are you trying to change? Frequency will be in the 25000 range.
24.5K would be shorthand for 24500. Have you tried entering this?
coolideas
Yes
Detail Current ParameterNew Parameter
Frequency 20190.00 MHz20192.500 MHz
Symbol Rate 2500012.500
FEC 2/35/6
Out of interest...
What's the make and model number of your satellite receiver?
Rodders53
Saorsat not Saorview (the terrestrial one).
I'm guessing the 12.500 is really 12,500 so input 12500 - it's just something has got lost in the technical translation.
TJT1
Bearing in mind that our friends on the continent us a full stop as a thousands separator than the than the comma that we use, that's a pretty realistic stab in the dark Rodders. 😍
grahamlthompson
Saorsat requires a totally different lnb to the usual Ku Band Universal lnb. I take it you have one ?
It's very hard to get unless you live in Southern island even close to the ulster border.
Rodders53
There's a good thread on DigitalSpy that confirms the 12500 symbol rate.
Apparently, some sat receivers need the LNB Intermediate frequency deducting from the wanted tuning frequency as they don't do it for you (which one such user admitted to messing up the calculation).
Official Saorsat receivers one would hope could do this change without issue overnight?
80cm solid dishes or 1 metre in NW/SW apparently, and frequency reuse from some other Eutelsat spot beams mean fringe reception is not possible even with much larger dishes as it's interference limited. Much of NI is ok, and it also works in bits of Wales and the SW of England, allegedly.
coolideas
Out of interest...
Direct to walker tv.
Got another box in the end.
Correct. I got another sat box in the end since the TV would not change the parameters.
