Question UN75MU6300 poor video streaming quality
Discussion in 'Samsung TVs Forum' started by FlyingFiddle, Aug 3, 2018.
  1. FlyingFiddle
    FlyingFiddle
    Aug 3, 2018
    3
    4
    Halifax
    Hi, I just bought a UN75MU6300 model from Costco (Canada) and spent the night setting up and testing the Tizen apps. The system itself is quite fluid but I found that built-in apps, specifically Youtube and Netflix, have poor streaming quality.
    For youtube, when I run many 4K videos, the app tends to automatically select a lower rate such as 480p. When I force it to 1080p, occasional pauses will happen. At 4k quality, the video would chop a lot.
    For Netflix, the video will start streaming at a very poor quality, slowly get better but never as good as even my current 720p TV with a Chromcast.
    My TV is in the room that is very close to my router. I even used the Internet app to go to Internet Speed Test site of Google and got very good test results (over 20MPs download and similar upload, I have Bell fiber internet). So I am confused as to where the problem might be. Maybe it just can't sustain a good streaming rate? Or the fault of the apps? Has anyone had a similar problem with their TVs?
    I was hoping NOT to have to use a Chromecast Ultra or a media box for this TV as it's Tizen system has all the streaming apps I would need. Would be a shame if I can't use them to stream content at decent quality.
    Thank you!
  2. mark00754
    mark00754
    May 6, 2018
    uk
    hi is that 20mbps or 20MBps?
    are you using wifi or Ethernet?
  3. FlyingFiddle
    FlyingFiddle
    Aug 3, 2018
    3
    4
    Halifax
    Hi, I still have the streaming quality problem when I am using wifi. My web-browser based speed test was suggesting a fine speed but that doesn't translate into decent youtube or netflix video quality. It's a shame.
    I have now switched to using Ethernet and it's much better. All youtube 4k video now plays nicely.
    I am using those Ethernet through power line devices from D-link, if anyone is interested in this solution.
