PRY4SNO
New TV, odd issue. Amp is new as well (Harmon Kardon AVR1510), but it works fine with different sources (laptop via HDMI, cable TV tuner).
At first, getting the sound to work with Netflix and YouTube was a real challenge. Turned out I had the wrong HDMI out from the TV, as HDMI2 is the only ARC compatible port. Once I switched from HDMI1 to HDMI2, digital sound worked great.
Then, once in a while, sound wouldn't work through my amp and only on the TV speakers. I found that if I turned off both the TV and amp and restarted, sound would restore.
Now, I get no sound through my amp while using the SmartHub apps. Swtich from cable to smart TV and nada.
I've tried turning off the AnyNet+ with no improvement.
Suggestions?
Suggestions?
