un46fh6030 vs un46f5000
Discussion in 'What Is The Best TV For You?' started by Gghertz, Jan 31, 2014.
  1. Gghertz
    Gghertz
    Jan 31, 2014
    2
    Samsung. Don't want smart TV, 3-D is not something I would use. Number one concern is picture quality. I watch football but don't have a major problem Now with the 60 Hz that my eight-year-old LCD produces but has quit working. Would like to consider Sideview issues And appropriate connectivity with other devices. Would like decent sound quality but will purchase a sound bar. The 6030 has 3D, does that mean it will have better picture quality and other improvements that would be helpful even when watching 2-D? I think the 6030 uses backlighting while the 5000 uses edge lighting, which will give the better PQ. Any thoughts on which is the better looking frame?
  2. Ossie77
    Ossie77
    Nov 11, 2012
    1,616
    +173
  3. Ossie77
    Ossie77
    Nov 11, 2012
    1,616
    +173
    I'll add that the only thing the F5000 doesn't do very well is 24p. There is mild judder sometimes and blu rays aren't quite as smooth as they should be.
