UMD titles from dvdsoon
Discussion in 'Blu-ray & DVD discs' started by figlio, Mar 1, 2005.
  1. figlio
    figlio
    Dec 17, 2002
    180
    Malta
    I just noticed that DVDSOON have some titles that are cheaper but they are marked UMD.What are the difference between the titles?
  2. paul1672
    paul1672
    Jul 31, 2003
    2,675
    71
    norfolk
    +54
    afaik they are for the sony psp mate.
  3. Rob20
    Rob20
    Jul 3, 2004
    3,282
    +779
    The UMD format was created specifically for the PSP. Not only for games but also for movies. The UMD disc is an 8cm disc that comes in a caddy and can store 1.8GB dual layer. I'm sure that Sony will release other compatible devices and will probably try to convince other manufacturers to do the same.
  4. Ger
    Ger
    Jun 9, 2003
    1,620
    Ireland
    +83
    Apparently UMDs will only be pressed by Sony and won't be available in a "UMD-R" style format to burn at home. I suppose this makes sense from a piracy pov, but its a real kick in the :eek: for a new format. I can't see many people buying both the DVD and UMD versions of a film (or just the UMD).
  5. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Already? :thumbsup: What region are they? I have a Jp PSP. (not much out on it at the mo, so a few movies might be fun to have!)
