UMD Emulator Help
Jan20
I have Winning Eleven which I bought from here and I've read that its much quicker when running off the UMD Emulator. I've downloaded the emulator, but can anyone give me a step by step on what I do please? :smashin:
Jan20
Got Fastloader 7 working no problem, dumped Everybody's Golf and it worked a treat. Version 8 is beyond me, I get into the screen fine but when I try to load an ISO I get sent back Home. Very annoying!
Anyone got Fastloader to dump Winning Eleven? The resulting ISO won't work on V7.
chrislad
I had the same problem with Version 8 as well.
You need to use DevHook .21 or .22 for Winning Eleven.
F
FGEvans
Version 8 works fine for me - you can have version 7 and 8 running on the same machine. If you can load version 7 into a psp then loading version 8 is identical (the iso files are simply named differently when located on the psp).
Version 8 simply has a different iso file on the psp. Put the winning 11 iso in the correct folder and run it.(find the version 8 emulator logo on the psp under memory card/game) run version 8 and load iso.
It will then return you to the home screen- simply then go to the game option on the main psp screen and in the UMD section you will see the wiining 11 game (simply look as you would with any real UMD).
version 8 fools the psp into thinking that you have the actual winning 11 UMD in it.
jinky32
Established Member
wohoo, i've been waiting to use that image - it's not me by the way.
cmon guys, umd emulator is supposed to take you back to the front page, then you select the umd icon and it's the game you loaded. RTFM!
Jan20
I've now got WE9 to laod up, it gets just past the initial screen and then goes black. Oh lord!!!!
chrislad
I did read the readme! file and it mentioned nothing about that.
*shrugs*
DevHook works fine for me anyway.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
