UltraMote Extender® or Laser- / Electric Dog- PDA-IR-Extender
Discussion in 'Home Cinema Control & Remote Controls' started by Nic Rhodes, Jan 13, 2005.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Which do people think is better?
  2. Fishbones
    Fishbones
    Jan 26, 2004
    126
    Madeira
    I have the Ultramote. Works very well for me. Bit of a hassle to order as you need to send a code generated by the software upon instalation on a compatible PDA.
    PDA-IR seems to be discontinued.
  3. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,019
    Southampton
    +236
    As Fishbones stated,the PDAir's are no longer manufactured,but if you get the chance to buy one on the second hand market,snap it up,as they work extremely well.
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I have a the discontinued one already but I might need another one, I was intreagued by the dual LED for wide dispersion? They aren't much money....but if it was worse..
  5. museumsteve
    museumsteve
    Jan 28, 2001
    7,632
    3
    Nth Hampshire
    +1,023
    I'm desperate for either if anyone wants to offload one ;)
    Has anyone looked at using any other kind of IR booster or pyramid system for better dispersion. My main isue is my PJ which is above my seating position whereas all otehr equipment is in front of me. Just a thought.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    hence my interest in wide dispersion
  7. museumsteve
    museumsteve
    Jan 28, 2001
    7,632
    3
    Nth Hampshire
    +1,023
    I may pop to Maplin and see what options they have with regard to using some kind of IR receiver/sender and will let you know how it goes (if it does) :)
  8. alandbush
    alandbush
    Dec 18, 2004
    183
    Bournemouth
    +20
    museumsteve,
    Before I was able to buy an Ultramote IR extender, on ebay, I enquired about several IR receiver/sender solutions.
    I found that the IR receiving and sending range of approx. 1-3 metres impracticable for my situation. However, your brief description suggests you can position the receiver within reach of your remotes' range and if you can position the sender close to the pj the RF signal, between the receiver and sender, has a range of 10-20 metres. Sorted.
    Good luck in your investigations.
  9. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,019
    Southampton
    +236
    I put to good use,a pair of Powermids,that I previously wasn't using.The receiver and sender are in the same room,and used in conjunction with the PDAir,I can point the Simpad practically in any direction,and the ir signal gets transmitted to the IR receivers on my amp,plasma dvd etc.
  10. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Which software are you using with the extender..? Ultramote doesn't support .ccf's, PDAwin has no support and NetRemote doesn't support an extender... :thumbsdow
    Now if NetRemote supported the UltraMote extender I would jump...
  11. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,019
    Southampton
    +236
    Remote Control II from Wincesoft.
    Website
  12. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Doesn't look like it supports .ccf files..?
  13. dalepearson
    dalepearson
    Aug 27, 2004
    181
    +11
    HIya guys, I am just configuring a DELL AXIM to use as my remote. How have you guys set up volume controls and channel change, as on the real pronto you have hard buttons.
    Look forward to your response.
    Dale
