Question Ultra short throw, small image projector
Discussion in 'Projectors, Screens & Video Processors' started by karlsj, Sep 23, 2018.
Tags:
  1. karlsj
    karlsj
    Sep 23, 2018
    3
    4
    Stockholm
    Hello forum,
    I need help finding a very small projector able to project a clear image from 35 cm distance. The image will be round and no larger than 15 cm in diameter. It's for an art piece. In my mind there'd be several options on the cheaper end of the spectrum (budget allows for $200 max), but I thought it best to throw out the question among the knowledgeable before making a choice.
    Best wishes
    K
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,434
    Do you have a diagram of what you are planning and some indication of ambient light levels.
    Joe
  3. karlsj
    karlsj
    Sep 23, 2018
    3
    4
    Stockholm
    Thanks for the reply, Joe!
    [​IMG]
    Imgur
    the projector will be mounted inside an old military radar. I will empty it from it's components and place the projetor at the bottom, throwing up onto the radar screen. It will be rear projected as well. Forgot that in my initial question.
    I can dim the lights in the space and I have alot of different lighting choices.
    The footage I'm using is very abstract and low quality (military research footage of herring in a watertank, don't ask :), it's basically just black dots moving on a red surface.
    Karl
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,385
    The Borders
    +3,434
  5. karlsj
    karlsj
    Sep 23, 2018
    3
    4
    Stockholm
    Hey Joe,
    yeah, me and the production team are looking in to it. But, I'd rather go for an out of the box solution to save time experimentation. But, we might end up there.
