Question Ultra Short Throw Projector recommendation / Questions?
Discussion in 'Projectors, Screens & Video Processors' started by TheBlueRaja, Jun 9, 2018.
  1. TheBlueRaja
    TheBlueRaja
    Feb 26, 2006
    642
    +69
    Never had a projector before but i think I'm looking for a Full HD Ultra Short Throw Projector that can project onto a 77" screen from as little as 60cm away, but preferably 10 to 20cm closer if possible.
    I say 77" because that seems to be a standard screen size that i can purchase and it will fit my room well.
    I'd also like to be able to position it slightly off center as i have a center speaker right in the middle of my unit i intend it to sit on and i obviously don't want it in front or on top of that.
    I know long range projectors can do this but i wasn't sure about ultra short throws.
    My budget is around £1000.
    I have seen the Optima GT range that talk about 100" from 30cm away but 100" is a bit much for me so im looking to understand if i can make it smaller than 100" and if i can then have it off center.
    And you lot might have better recommendations anyway. ;)
    Thanks folks.
  2. Mark_a
    Mark_a
    May 27, 2005
    3,219
    +675
    If you want it smaller simply move the projector closer to the wall/screen. Obviously there will be a fundamental limit once you've actually butted up against the screen, but you should be able to get it down to 77".
