Ultra HD + HD & HD Pack Question
Skizm123
Hey,
Looking for a bit of advice on whether I can remove the HD pack that is currently in my package or if I need this on top of having the Ultra HD + HD pack. Its a bit confusing on the sky website if the Ultra HD + HD pack gives me access to all the HD channels (and essentially paying £10 per month rather than £4 for the same content). Have pasted an image with the HD pack currently active and the Ultra HD + HD pack.
Question is, if I removed the HD pack will I still have access to all the HD channels?
logiciel
Almost all of these should be a lot less, including HD which should be £0.
Renogotiate!
GeeZus
You need both to get 4K content. If you remove the HD pack UHD pack is also knocked off
If you remove the HD pack then you only get the free to channels in HD.
For £4 a month for both HD and UHD it's decent but you can definitely do better on the rest of the package
zAndy1
He's paying £10pm for HD and UHD isn't he, where does the £4pm come from?
zAndy1
But there's a separate £6pm HD pack as well?
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
