Ultra budget amp & bookshelve speakers?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Pezerinno, Sep 1, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,427
    71
    Southsea
    +69
    Hi guys, I'm after suggestions for a cheap intergrated amp and some bookshelve speakers. Looking to go second hand with a £400 max budget. Will be using a Tag Dac20 with some sort of transport (dvd/sacd player). Room is fairly small and I tend to listen to alternative/rock(&roll)/indie music although occasionally some hip hop and blues - nt sure if that makes much difference when choosing speakers...
    What kit should I be trying to demo? All advise welcome :)
    Cheers, Nick.
  2. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    Hi Nick,
    Firstly, I see you're Portsmouth-based! Me too! As you probably know, there's two main stores here - Now That's HiFi in Arundel Street. They stock Mission/Tannoy/NAD/Marantz gear, as well as Sony and Pioneer. Audio-T is in London Road, North End. The stock Rotel/B&W/NAD/Monitor Audio as well as others. See: http://www.audio-t.co.uk/html/stores/portsmouth.html for details. We could do with a few more stores here!
    £400 should get you a nice setup for that. I'd consider the NAD C320BEE amp - as it happens, I'm trading my Yamaha receiver and a pair of Mission m30 speakers in for one on Saturday, as I've decided to go back to 2-channel stereo. The RRP is £220, IIRC. Another contender is the Rotel RA-01, but it's priced slightly higher at £250.
    As for speakers, Monitor Audio Bronze 2's seem to be highly regarded as a match for this amp. RRP is about £180-ish.
    You might also be able to find some Mission 780s - these would be a bargain and possibly fairly cheap, as I don't think Mission manufacture them any more. Mission m71s or m72s are also a decent budget speaker. Not too convinced on the m30 series - I have a pair of m30s and they definately are not as good as the m70s. Personally, I feel that the m70 range was better than the m30 range, but that's all IMHO. B&W also seem to be well matched with NAD gear, but I'm not sure on exact model numbers/prices - the DM303 could well fit the bill. They also have good synergy with Rotel - B&W are the Rotel distributors in the UK.
    Best thing you can do is to try and audiition as many items/combinations as possible and see which you prefer the sound of. You may well be wise to bring your DAC along. I realise the transport characteristics can possibly cause differences in sound, but at least by bringing your DAC-20 with you, you'll have a pretty sound idea of what you can expect.
    Hope this helps!
    Cheers,
    Neil
  3. harv
    harv
    Jul 26, 2005
    254
    london
    +4
    Audio T and sevenoaks in bristol sound be able to internally ship stuff between stores. Sevenoaks was a £10 last time I used it. They've got an Arcam A65+ or Marantz 7200 for around £200 which have had goodish reviews, Speaker wise, B&W 602's should be in reach, Monitor Audio S1 and S2. Have a look,
    http://www.audio-t.co.uk/html/listings/index.php
    http://www.sevenoakssoundandvision.co.uk/stockclearance/stockclearance.html
    http://www.weymouthhifi.co.uk/website/home.html
    have got Musical Fidelity X-80 for £249 but they say its only in-store a bit of sweet talking might work. Oh and don't forget Kef Q1's recently replaced so available on the cheap, nice sounding but not the loudest or most bass. Good in small rooms though. Hope this helps and isn't too confusing.
  4. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,427
    71
    Southsea
    +69
    Thanks for the replies :) Neil I'm will be moving back up to Bristol in a couple of weeks (uni) so will most probably purchase everything up there - seem to have a few more shops also!. All those recommendations look sound - will try and arrange some demos. What do you guys feel about buying second hand from eBay - worth the potential risk?
    Cheers, Nick.
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,083
    +343
  6. nirmal
    nirmal
    Sep 12, 2005
    30
    Checkout the Cambridge Audio range. Possibly the best value for money if you are on a tight budget. Seems to get universally favourable reviews.
    Cheers,
    Nirmal :)
  7. pjdowns
    pjdowns
    If you are willing to go down the second hand route, then could I sugget the following
    Audiolab 8000A (Excellent amplifer)
    For speakers, I would probably recommend
    Epos ELS3
    Hope this helps
    Paul.
