Chaps & Chapesses....
The time has finally come for me to part with my hard earned cash on a DVD player. My requirements would appear to be simple, but my research here and elsewhere has only gotten me so far.
Having ruled out a HTPC (I spend all day working with PCs and just want to be able to come home, put a disc in and push 'play') I'd be grateful for any advice on offer.
Quite simply, I'm after the best PQ I can get when displayed on an 80" or thereabouts image from a projector - probably a Sony HS50. The only other requirement is that it uses HDMI due to the cable length (15m).
DVD-A & SACD are not important to me - I already have a Naim 2ch Hi-Fi that does me just fine.
From what I can see, my choice would appear to be one of the following :
Pioneer 868
Denon 3910
Arcam DV79
They all appear to have their own particular strengths and weaknesses - the Denons buffer and potential for scaling the image are appealing, but the reports of macro-blocking are a little worrying; the Arcams poor remote and 'huge' layer change pause I could do without, but the 480i/576i to an external scaler might be useful; the Pioneer can scale and output 480i/576i, but appears to suffer CUE problems...........
My other dilemna is the whole external scaler question....... if this really is the route I should be exploring then is there any point in buying one of these expensive players ? - would I be better off getting a cheaper player (2910?) SDI modded instead ?
Fear not, I have every intention of demoing all the contenders, although I fear it may be impossible to find a dealer stocking all 3....
So........ any feedback, good or bad, would be most gratefully received....
Cheers,
Mark
Pioneer 868
Denon 3910
Arcam DV79
Cheers,
Mark
