ULead VS11.5Plus.Fade to white-how ?
JH4
Can someone please tell me if Ulead VideoStudio11.5Plus has the option to do a simple 'fade to white' at the end of a video clip. I have searched throughout the options and can't get it. (The only thing I can find similar is the 'fade to black' in the Effects - Transition FX menu - but that only inserts between clips. I just want to end the clip in a 'fade to white'. The only fades I can find are audio.) I'm obviously missing something very basic here but I'm hanged if I can do it. My 'net bought' downloaded version seems to be missing the help file, which doesn't help matters.
Many thanks!
Sinaisid
Yes it's pretty easy - Select storyboard view and then in the gallery selector box select colour. Drag white into the storyboard view after your last clip and apply a crossfade transition - job done :thumbsup:
JH4
Many thanks - I thought it could be done somehow - I'll try that asap.
Still learning this program !
Welcome to the forum, btw.
Edit: Yeh, that works - cheers !
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
