Ulead Videostudio 9
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by russ hirst, Jun 19, 2005.
  1. russ hirst
    russ hirst
    Jun 18, 2005
    30
    11
    Harrogate, N Yorkshire
    Following an answer given to another question on this forum, I downloaded this programme and found it to be excellent, especially as I had been using MM2 up to this point with good results (apart from some odd Audio glitches).
    So,now I am a convert but having spent some time "playing" with VS 9, I cannot find the fade in and fade out controls. Can anyone help please? And I do hope they aren't big buttons I have missed that say "Fade In" and "Fade Out"!!
    Cheers.
    Russ
  2. fiara
    fiara
    in the upper right side, click on the drop box->transitions->f/x
    and it should be here somewhere
    g luck
  3. Brian110507
    Brian110507
    You need to use the "Crossfade" transition - if your talking of the beginning and end of your video you will need to put a few seconds of plain black colour at the beginning to fade in from and similarly a length of plain black at the very end to fade out to. Remember that the black colour blocks need to be at least half the time you set for the cross fade or it will not work.
