Ulead VideoStudio 8 - jerky DVD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jchm, Mar 24, 2005.
  1. jchm
    jchm
    Feb 6, 2002
    151
    3
    South Notts.
    +11
    I've recently bought VS8 and have had no probs with capturing, editing & burning...
    BUT the resulting DVD-R is 90% fine but has some sections where sound and audio goes jerky for about a minute at a time when played back on my DVD player or my PC DVD drive...
    I've tried burning at a slower speed ( down to 2X) with no improvement.
    Anyone got any ideas?
  2. Brian110507
    Brian110507
    Did you stop ALL background processes including anti-virus software and disconnect from the internet while burning the DVD, if something else on your computer runs either automatically or deliberately while burning a DVD you can upset the burn process.
  3. fcat
    fcat
    Feb 22, 2005
    169
    16
    try a different brand of media, thats should sort it
  4. jchm
    jchm
    Feb 6, 2002
    151
    3
    South Notts.
    +11
    Thanks guys
    I'll give both suggestions a try.
  5. indexwheel
    indexwheel
    When you go to "Share" "Create Disc". you will find 2 icons in the bottom left corner of the create disc window. Click the right one, and this will give you the option of changing he mpeg2 compression settings. If it is set to a video data rate of 8000kbps (and you are encoding normal avi files), then you need to click "change mpeg settings", then "customize". Set quality to 100%, then Video Data rate to "variable" 6000 kbps. This should solve the problem, and give you the best quality from normal handycam avi's.
    Regards, Rob
