UKHDMI Cables
Discussion in 'Cables & Switches' started by xion2000, Jan 20, 2008.
Thread Status:
Not open for further replies.
  1. xion2000
    xion2000
    Mar 2, 2005
    40
    Middlesbrough
    +7
    Does anyone have any experience buying & using cables from UKHDMI.com.
    I.e. Shop service, Cable build quality & quality in use.
    The cables look excellent on their website & the prices appear very cheap compared to elsewhere.
  2. razor38
    razor38
    Feb 3, 2007
    391
    +36
    I recently bought some premium ones (1.3, 1080p) delivery was quick, cables are very good. I am happy that I bought from there
  3. xion2000
    xion2000
    Mar 2, 2005
    40
    Middlesbrough
    +7
    Thanks for the quick reply.:thumbsup:
    Was it the N Premium or the Premium. Do they look as good a quality in the flesh as they do on the website?
  4. lowmans100
    lowmans100
    Dec 20, 2006
    1,480
    +461
    I've bought the Premium N and they are great. Fast delivery not a stupid price and work just like it says on the tin. The 'braided' outer is a bit unusual because it's plastic not the material braid that I have on other cables. I don't know what the braiding does other than give some protection to the cable sheathing from rubbing so I'm not bothered. All that matters is they work, right?
  5. PSD
    PSD
    Feb 23, 2005
    1,312
    Tickhill NR Doncaster
    +110
    I concur, I went for the N premium, good quality cables for a super price. They were also delivered the next day.
    Happy customer.
  6. rbee
    rbee
    Jul 7, 2007
    17
    3
    :smashin:Tend to agree, just bought two 'N' premium series for total of £12 for my Sky HD and Tosh EP30, looks the bees knees, good price, delivered fast - BUT.............unless I want to mess about swapping cables, not sure if they're any better than either the Tosh one that came with the unit, or even Argos's own cheapies. Anyone done any comparison tests please?
  7. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    For short lengths pretty much any properly assembled cable will do the job.
    Only need to start getting more picky once you start moving into 3-5m and longer.
    Read the HDMI stuff at http://www.bluejeanscable.com/articles/hdmi-cable-information.htm gives a very clear picture of the way HDMI cables are made and what really matters about them.
  8. Bytey
    Bytey
    Jan 14, 2008
    59
    11
    Cumbria
    +3
    Some insteresting stuff in that article. When I got Sky HD in 18 months ago, I shelled out about £70 on a 3m QED HDMI cable. I've now added some more equipment and need to add a HDMI switch, and as a result I need to buy a couple of shorter cables. I'm tempted to buy a couple of those 1.5m Premium N cables to run to the switch and then keep my QED cable from the switch to the TV. I'm sure it wont make the slightest bit of difference to the sky HD, but I'm not sure I'd feel right putting a £6 cable in the back of an Arcam FMJ139 DVD player. I think I'll buy a couple of them anyway, if I'm not happy then it's no great loss, and I can let you all know how I think it compares to my more expensive QED cable.
  9. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    That's easy to solve, just get a friend to buy the cheap cables for you then you give him £70 each and you'll feel a lot better about it :)
    I've yet to hear of a blind test that can show a difference between two working HDMI cables.
    If a cable has been badly assembled then the differences are obvious but on short cable runs with properly built cables I defy anyone to spot the difference between £10 and £70 spent.
  10. Bytey
    Bytey
    Jan 14, 2008
    59
    11
    Cumbria
    +3
    LOL
    I've placed an order for 2 of the Premium N cables, so time will tell :D
  11. PSD
    PSD
    Feb 23, 2005
    1,312
    +110
    I have a clearer audio and QED HDMI cable, both 1 metre and neither look any different to the cable included for free with my DVD player.....
    As has been said above, under 2 metres it really makes no difference at all.
  12. ben.bayliss
    ben.bayliss
    Feb 4, 2007
    1,198
    63
    +136
    Why not? I bet if you opened it up you'd find that the internal wiring isn't very posh at all! :)
  13. GreasyWeasel
    GreasyWeasel
    Aug 8, 2005
    355
    Shropshire
    +13
    I recently bought two 5m Premium-N cables and they are great. I'm very pleased. I'm aware that the longer the cable the better the quality needs to be which is why I spent big on a 15m cable for my projector but I honestly can't fault these 5m cables. I have tested them out with Sky HD and my PS3 running 1080p blu-rays. :thumbsup:
  14. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    I have 2 Premium N ones running though a conduit in the wall that would be a bu--er to get out if I had to :eek:
    Very pleased for the money. Highly recommended.
  15. Member 213491
    Member 213491
    Aug 30, 2007
    860
    43
    Oxford
    +101
    Hey thanks for your support :)
    we have added a lot of stock and new SKU for the Premium Line, previously clients only had a limited choice for 10, 15m or 20m now we have added 11,12,13,14,16,17,18 and 19m.
    Any comments that can help us improve?
  16. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    What? No half metre sizes then? 11.5, 12.5. 13.5, ..... :D
    Actually it is very useful to be able to buy something that is pretty much exactly the length you want. No more loops of space cable hidden behind the av furniture.
    So well done on supplying such a range of lengths
  17. luke31
    luke31
    Jan 16, 2008
    20
    3
    I ordered today :thumbsup:
  18. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    Hi there, would like to order a cable from your site. Do you deliver to south Ireland?
  19. Mars2003
    Mars2003
    Sep 17, 2005
    116
    +7
    I've ordered a 15M Premium HDMI cable to send Sky HD to my projector room. Will report back on how that goes in a couple of days. Assuming it works then it's fantastic value at that length.
  20. Member 213491
    Member 213491
    Aug 30, 2007
    860
    43
    Oxford
    +101
    OMG : WOW how do u know?, we have ordered half metre cables also and we shall get them in mid march :)
  21. Bytey
    Bytey
    Jan 14, 2008
    59
    11
    Cumbria
    +3
    Wow, my cables arrived today, that was quick. I must say I'm impressed. Sky HD on a 40" screen just as good as through my QED cable. No doubt I'll be buying another one of these when I get around to buying a PS3.
  22. AnilS
    AnilS
    Mar 4, 2005
    1,889
    +218
    I had the same experience. Excellent cable/service/price.:thumbsup:
  23. Mars2003
    Mars2003
    Sep 17, 2005
    116
    +7
    Got 15M premium HDMI today, used it to send SKYHD to my projector room. Works flawlessly.
    Thanks to UKHDMI
  24. uberTreetops
    uberTreetops
    Oct 19, 2005
    5
    Wooburn
    Placed an order on Tuesday 22nd Jan. No delivery; the tracking number is not recognised by DHL; no response from the company either on the phone or by e-mail.
    I would not recomend using this company it maybe a good product but the serivce is terrible:thumbsdow
  25. xion2000
    xion2000
    Mar 2, 2005
    40
    Middlesbrough
    +7
    Don't be too hasty, looking at everyone elses posts they normally give an excellent service.
    I started this thread as I had never used them before, I have since purchased a couple of cables & the service was 2nd to none (ordered Monday evening, items arrived Wednesday morning)
    Anyone can make a mistake, I'm sure you will get your order eventually.
  26. Member 213491
    Member 213491
    Aug 30, 2007
    860
    43
    Oxford
    +101
    I am sorry andrew is looking into the matter, hmm we gave your goods to DHL and we have a proof of dispatch... DHL is looking into the matter and will update you in 24-48 hours.
  27. AVJay
    AVJay
    Dec 20, 2007
    625
    +19
    Has anyone tried the "express" version of the UKHDMI cables ?
    They're more expensive on the website so i'm just wondering which cable to get...express or the n premium series. Is there a 'big' difference between them ?
  28. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I've been puzzled by the product positioning on the 'Express' as well.
    More expensive than the Premium yet no claims regarding 1.3 etc. so very unclear what the target is for them and why the price difference.
  29. xion2000
    xion2000
    Mar 2, 2005
    40
    Middlesbrough
    +7
    I Emailed UKHDMI a week or so ago asking them to explain in what order of quality the cables are, but have not had a reply.
    I think the info we want is something like:
    HDMI Express - Top of the range!
    HDMI ECO - Bottom of the range!
    If you look at the order the cables are listed on there site it looks like it could be the order of quality top to bottom, BUT the misleading thing is that the HDMI Premium cables come in lengths upto 20 metres?? Surely the TOP OF THE RANGE cable should come in the longest length
    Could we also have some info on the actual cable used in each lead & if there is a difference across the range?
    :lease: HDMIHEAD some answers!!??
  30. AVJay
    AVJay
    Dec 20, 2007
    625
    +19
    I hope he responds soon , I'm hoping to buy some tomorrow. :rolleyes:
Thread Status:
