UK Z1 popped after 280hrs.
Discussion in 'Projectors, Screens & Video Processors' started by agentdavo, Nov 10, 2003.
  1. agentdavo
    agentdavo
    Yes.
    The Z1 popped last week after 280hrs. I had a little bit of warning before it happened. The pj went really quite dimm.
    The unit is only 3 months old too.
    I posted it for warranty today. Hopefully there'll be a quick turn around of 2-3 weeks. Anyone else had this problem? How likely is is it that it will be free repair bunder the warranty? Any ideas how i could argue this. Is it the bulb thats faulty, or the units thermal management? New bulb or new unit?
    Any advice would be appreciated.
    I'll keep you updated.
    David.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I think it needs to be under 90 days for a bulb to be replaced under warranty....
    ad
  3. Ricco
    Ricco
    Most manufacturers have only 90 day lamp warranty, don't be suprised to receive an invoice for a new lamp and labour......
  4. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    I thought it was 6 months.
    At least NEC do a 1000 hour or 6 month guarantee, whichever comes first basically.
    So if you bulb pops before 1000hrs AND is less than six months old you get a free replacement.
    So I'd have thought others would have similar policies. Worth checking the small print on the guarantee agentdavo.
  5. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    most do seem to go for 90 days with bulbs...... some places will do better, I think that germany gives better warranties as an example.
    ad
  6. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    Sorry to hear other machines go pop too
    i thought it was only Panasonic !!!
    mine went after 4 months but a fix was only a 2 day turnaround
    picked up Tuesday and back Thursday , this week
    so i can still enjoy the rugby Hoooray
