UK Suppliers of Sony VW11 & Da-Lite
Discussion in 'Projectors, Screens & Video Processors' started by nigel_williams, Jan 5, 2002.
  1. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    I'm about to replace my 32" Wega with a projector system and considering the Sony VW11 - I had a demo of the VW10 back in Novemeber and was very impressed.
    So far, the best prices I have are:
    VW11 £4,250 (PRC), £4,372 (Ivojo)
    Ivojo also stock the Da-Lite Model C (80" x 45" 1:1.78 92" diag)
    Has anyone else used this screen with the VW11? My room is approximately 13 ft in length and 7'5" high.
    Any better prices/suppliers out there?
    Thanks,
    Nigel
  2. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
  3. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Thanks for the info/links. Managed to speak to another supplier in Home Cinema Choice and they can do a VW11 from stock for £4,100 delivered! Best price so far, doubt that anyone will beat that.
    They also quoted £299 for an 83" Draper Luma screen which I presume is OK.
    Nice setup BTW! I might need to put trunking under the floor for my setup as I don't think ceiling mounting will work for me.
  4. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    sounds good ,i had a owl screen before and changed to da-lite it did make a differance
    try and take a look at the projector if you can ,and hopefully you can exchange it if you have problems
    goodluck
  5. Metric
    Metric
    im using a dalite from direkt2u and am very happy with it
  6. WSquared
    WSquared
    Jan 31, 2001
    215
    Bristol, UK
    +3
    Me too(Matt White), along with my 11HT. Looks great.
