Over the past weeks I've been excitingly reading the positive Samsung reviews, and also managed to take a look at one in a shop on Tottenham Court Road. Have to say i was impressed, best PQ ive ever seen from an LCD, and this was with a poor fuzzy input.
Anyway, was looking into prices online, when i noticed the American model the Samsung LNR238W. At first i thought it was the exact same TV, but then i noticed the change in inputs (check the bottom of this link)
http://www.tvauthority.com/LCD-TV-and-Monitors/Samsung-LN-R328W.asp
Instead of 1x Component + 2x SCART, it has 2x Component + 2x AVI.
What im asking is do the Americans have a better deal? Would you prefer the American or UK (considering it may be posisble to get this TV cheap on import)? I'm undecided..most of my devices currently work on RGB, but 2 components would be well handy, espcially once the Xbox360 is realeased.
Also in not sure if you can have RGB inputing through the AVI ports, or if RGB is scart only?
Further investigation revealed that the 32" and 23" models have the exact same set of inputs..which means the 23" is SERIOUSLY well connected, the perfect TV for a bedroom + videogames!
