UK PSP with US Games & Films
Discussion in 'Playstation Forums' started by pemberto, Sep 11, 2005.
  1. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    I am in need of some advice :lease:
    I know very little about the PSP and I am just about to buy my son a PSP for his birthday. If I buy a UK PSP can I play US games and films.
    Also does anyone know if the PSP will support the 2GB and 4GB memory sticks.
    Thanks in advance.
    Pemberto
  2. tom_g
    tom_g
    Feb 23, 2005
    148
    alos see for more info- http://www.avforums.com/forums/showthread.php?t=234585
  3. jerkyboy
    jerkyboy
    You can play any games on any PSP as they are region free.
    As for films, unfortunately they are not so if you have a UK PSP you have to buy UK films.
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    UK PSPs are R2. Only Jap and UK UMD films will work on R2 Jap/UK PSPs
    If you buy a US PSP, you'll need to import films from US, as it is R1
    The PSP supports the smaller ver of MS http://www.emartbuy.com/uk/catalog/item/miscl/itemListResult.aspx?sp_id=3&par_1=GBP&par_2=Standard&par_3=memory%20stick%20duo&par_4=
    Sandisk are cheaper, but transfer data faster. Official isn't always best. The long ver of MS do not fit in the PSP. Buy off ebay for cheaper. Max at the moment is 2gb (but thats way too expensive). It'd be better to buy 2 x 512mb or 2 x 1gb
  5. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,098
    Yeovil
    +387
    Are we not region 2 along with jap and the yanks region 1?
  6. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    R1 = Usa Psp
    R2 = Jap/uk Psp
  7. NackNack
    NackNack
    Aug 28, 2005
    3,439
    68
    Northampton
    +97
    Bear in mind you can get a white one (Japanese, but you can select it in English) from Yesasia.com, free delivery and it'll be original. :) Around £170.
  8. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    thanks for heads up. its lack of sleep you see
  9. theboyjb
    theboyjb
    Anyone know what firmware a US model would come with?
    I am visiting shortly and not sure whether to buy from the US or buy in the UK. Not bothered about UMD movies at all, but might be keen to get involved in the homebrew side...
  10. BuzzLightyear
    BuzzLightyear
    Jun 3, 2004
    16
    Just got back from the US and the one I bought in EB had pre 1.52, not sure what it was, just know that the first game I put in had an option to upgrade firmware to 1.52.
    Hope this helps
  11. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    Yeah, my US one came with 1.52 as well
  12. theboyjb
    theboyjb
    Cool, thanks. Prices at the main stores (Circuit City etc) seem to be $250 + sales tax.... or can I do better?
  13. NackNack
    NackNack
    Aug 28, 2005
    3,439
    68
    Northampton
    +97
    Look for bundles, or pre-owned ones.
