UK Panny ES10 no good in Switzerland?
videomitch
Took a UK bought Panasonic ES10 DVD recorder to use in Switzerland but the TV channels ( supplied thru cable) are not stored properly-bad picture and lot of sound distortion. Can anybody tell me what I've done wrong, please.
JayCee
You didn't check/think to ask before you bought. :rolleyes:
Switzerland uses a different TV broadcasting standard from the UK.
maldonian
The UK tuner will not work properly in Switzerland, but the AV inputs and outputs (e.g. the SCART connectors) should work normally.
videomitch
Thanks, Jaycee. What system do they use and can it be made to work with a hack?
videomitch
Thanks, Maldonian. AV etc did work, so at least I've got a DVD player!!!!
P
pinatubo
Switzerland uses PAL B whereas UK uses PAL I - the difference is in the audio carrier frequency.See here:-
http://www.ee.surrey.ac.uk/Contrib/WorldTV/broadcast.html#country
I don't know if your recorder RF tuner input can be altered in the menu setup.Have a look.
Alternatively you may need to install a cable decoder box between the cable input and the Panny which could then be linked using AV connections which would bypass the RF problem.
maldonian
Switzerland uses PAL-B (VHF) and PAL-G (UHF), the UK uses PAL-I (UHF). The principal difference between PAL-B/G and PAL-I is the sound to vision carrier spacing (PAL B/G: 5.5 MHz, PAL I: 6 MHz). TV tuners use this fixed spacing to receive the sound (a technique called inter-carrier sound). The sound circuit in a UK TV (or recorder) is tuned to a fixed frequency of 6 MHz. If you take a UK TV or recorder to a PAL-B/G country the sound circuit will be incorrectly tuned for the 5.5 MHz inter-carrier sound. Another difference in Switzerland is the extra sound carrier used to transmit stereo sound (the UK uses Nicam). I think the intercarrier spacing of the other carrier is 5.74 MHz.
The tuning is probably achieved by a ceramic filter. Multistandard tuners have several filters and switch between them.
