UK PAL xbox + plasma screen = ?
Discussion in 'Xbox Forums' started by stigdu, Oct 6, 2003.
  1. stigdu
    stigdu
    Mar 23, 2003
    1,658
    Sutton
    +218
    Hi all -
    Just got an X-box (uk, no mods) and want to be able to play progressive scan titles on it on my plasma.
    My PS2 can do this (Soul Calibur 2), but I just wanted to know whether my xbox can too.
  2. phenom2003
    phenom2003
    You'll have to get it modded to output proggresive scan/HD. Try an Xecuter2 for £30 (install it yourself) or £70 (installed for you.)
  3. stigdu
    stigdu
    Mar 23, 2003
    1,658
    Sutton
    +218
    Thanks phenom.
    Where can I get one of these from please?
  4. V5-APS
    V5-APS
    May 7, 2001
    637
    London
    +10
    How can you confirm that the output is progressive scan??
    I have a modded my Xbox and have the MS HD kit attached, going to my Panny Plasma via the tuner box, which suprisingly has Component input!!
    The picture does look sharper at 480P, what else do i look for??
    Also, when playing PAL dvd's (I know, I do have another DVD player) should i expect the picture to be a little 'jittery' when in PS NTSC mode.
  5. phenom2003
    phenom2003
  6. stef290175
    stef290175
