UK or USA ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by T_om, Dec 30, 2004.
  1. T_om
    T_om
    I have around £400+ to spend on a new camcorder, can anybody recommend a decent model?
    i am going to the states in two months, am i wise to hold on and make my purchase there for half the money? what are the cons when buying in the states?
    Any feedback would be most welcome.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Cheaper USA v UK purchase of a camcorder has been covered on a few occassions in the past. This thread should cover what you need to know.
    Mark.
  3. T_om
    T_om
    Thanks very much !
    After reading the sent threads, i will not take the risk of buying from the states.
    Any recommendations on a decent camcorder in the U.K. for about £400
    i am currently using a Panasonic DS27. Looking to upgrade
  4. El Indio
    El Indio
    Jan 1, 2003
    35
    Apart from phsical size, do not expect much of an 'upgrade'. DV camcorders have not changed much in five years (from video POV). 1/4 inch CCD (like in your cam) is still considered 'desirable'.
    The 3CCD Panasonic GS120 seems like the biggest leap you could make, although it may be slightly outside your budget (in the UK that is!).
    El
  5. DirkoDick
    DirkoDick
    Look at the Pana NV-GS400E. The PAL model is sold in the US and a helluva lot cheaper than can be bought in the UK or in Aussie. Even with paying taxes etc it is still half the price for me to buy in the US and ship it to Australia. I could buy 2 to cover warranty problems and after warranty period sell one and still be in front
  6. Norbert666
    Norbert666
    Dec 15, 2004
    168
    +4
    Bought mine a couple of weeks ago for £420 at ebuyer ;)
  7. Norbert666
    Norbert666
    Dec 15, 2004
    168
    +4
    I looked into buyng in the US (my brother-in-law lives over there and was coming over for xmas) and in the end decided it wasnt worth it. The price difference is negligible between the PAL versions, and the really cheap ones you find in the US tend to be gret imports already. You will not get any Panasonic warranty.
