UK GT4 and 1080i HI-DEF ???
J
jerkyboy
Does anyone know if the UK version of GT4 supports 720p and 1080i HI-DEF.
Its in the Jap and USA versions, so hopefully they have kept it in the UK release.
Malone
I cant back this up with guaranteed info but I have read that because of our PAL 50 hz they cannot have hi def.
Try this website for a fair bit of info.
Matt
w3dal
cant wait to get this game.....
release date is next Friday isnt it??
Best price on-line i have found is £28.99 delivered
Dal
Out next Wednesday according to HMV, Amazon and Game websites. Does anyone now if it will have a progressive scan option?
Wil
Dean
Hmmm may have to get one of those racing wheels when i get this next week :D
CAS FAN
Got the NTSC version and the 1080i output is nice (but for some reason not as sharp as the X-Box output on 1080i games). The graphics are also flawed with ghost cars going all stripey blue. My PJ outputs 1080i fine via the X-Box so I know it's not that causing the problem.
Not sure about the PAL version having 1080i but my guess is that it won't as they always seem to leave out the PAL areas when HD is concerned.
The game itself is average IMO and is let down by awful collision detection (you bounce off thin air or polythene strip barriers!) and dreadful AI. It's fun playing a mate just as GT3 was but essentially it's just a bigger and slightly nicer looking version of GT3 with a few gimmicks like Photo mode chucked in!
Worth getting still but i'd much rather play PGR2 and Forza is looking much better IMO. Also GTR on the PC is supposed to be amazing, although very hard & realistic!
Yes the wheels look superb (with their 900 degree steering) and should add a lot to the experience!
geeWcee
Hi guys, how do you get HD output from a PS2? I only just got one and havent even had time to try it out yet. Really looking forward to GT4.
Is there a HD kit like the xbox one?
danvitale
Yes theres a component AV kit thats available on ebay for £6 (just search for "PS2 component").
Ill be buying one.. I think the UK GT4 Prologue had an option for 1080i so I cant see Sony removing the full versions 1080i option..
harrisuk
I dont think the high def feature will be available on the Pal version. I dont think any Pal PS2 titles support it.
CAS FAN
The PS2 doesn't have a HD kit - you can get HD through a standard component lead. Quite a few PS2 games support 480p and a few support 1080i (ESPN Footie & GT4). For a list of HD games check here :thumbsup:
CAS FAN
Yeah the picture is a similar improvement over RGB as you get between X-Box RGB to 480p. I don't see why the Pal versions wouldn't support it as they would have to produce another no Prog scan version of the game to make them not support it and that would cost more.
Malone
gthom3 said:
Got the NTSC version and the 1080i output is nice (but for some reason not as sharp as the X-Box output on 1080i games). The graphics are also flawed with ghost cars going all stripey blue. My PJ outputs 1080i fine via the X-Box so I know it's not that causing the problem.!
My PJ supports 1368ish by err 960ish I think but I cannot display 1080i fopr some reason. Any ideas?
Matt
CAS FAN
Not sure why, which Sony PJ do you have? Does it say in the instructions that it supports 1080i (or 1125i which I think is the PAL alternative). My Epson displays the NTSC high def resolutions but the OSD shows them as PAL figures so that 480p (whilst output as 480p) is displayed in the OSD as 525p. If no prog scan is being output then it shows as 525i.
Malone
I have the NTSC version of GT4 and the Pj is a Sony VW-11HT which I believe supports that resolution??
Matt
Malone
Compatibility: HDTV:
1080i,720p
EDTV/480p: Yes
SDTV/480i: Yes
Component Video: Yes
According to this it does??
I must be doing something wrong??
Matt
CAS FAN
So I take it you have the PS2 connected via component. If that is the case then all you need to do is go into the screen options (there are two widescreen TV's one with colour stripes & one without - select the without one) and there is a choice of 480p or 1080i as your resolutions. :thumbsup:
Malone
Yep
I dont have those selections on mine it reads the input and selects automatically but with 1080i I just get no pic?
All i get is a selection of what type of input ie component/ DTVYPBR/Computer.
Matt
CAS FAN
I was referring to the screen settings in GT4 not the PJ itself. What happens when you select 1080i in GT4's screen settings? Are you saying that you've tried setting the game or the PJ to 1080i?
Your PJ will only show a 1080i image if the PS2/game is outputting one so select it in the GT4 screen settings bit (which is what I was referring to with the 2 TV's).
Malone
:oops: Sorry, yeah when I switch 1080i on the PS2 it goes blank. I cant remember the 2 TV's for interlaced and progressive in the PS2 menu, if I have left it on progressive that maybe why then??
Matt
The Sheriff
Matt
1080i is a resolution of 1920x1080 which i image is why its not working for you, cos you monitor doesn't support it. Unless i'm wrong on this of course.
Nick
danvitale
I think you might be wrong.. Ive got a Sharp LCD tv and that is 1366x768 and that runs 1080i.. so theres some downscaling that goes on somewhere there.. maybe the projector doesnt have downscaling functionality?
CAS FAN
My PJ is 854 x 480 but can still display 720p & 1080i with downscaling. 720p is superb so it must have a pretty good scaler in it! :thumbsup:
dUnKle
Are you saying that the UK version DOES have the high def ?
I have PS2 connected via the component cable to my plasma - dont seem to have the option on mine
CAS FAN
My post is in relation to my PJ in general not GT4 - I only have the NTSC version of GT4.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
Latest News
Anthem launches latest AV receivers, processors and amplifiers
  • By Andy Bassett
  • Published
Naim and Focal discount premium music systems
  • By Andy Bassett
  • Published
What's new on Sky and NOW TV UK for November 2020
  • By Andy Bassett
  • Published
AVForums Podcast: 28th October 2020
  • By Phil Hinton
  • Published
Tom's Thumbs: What is coming to Netflix in November 2020
  • By AVForums
  • Published
