UK Gamecube - best video output?
Discussion in 'General Video Gaming Chat' started by ndenbow, Nov 2, 2004.
  1. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    Can someone give me some advice regarding video output on Gamecube. I have recently bought a projection system and want the best possible output.
    Also, if anyone suggests hardware or cabling could you suggest a place to buy from.
    Thanks.
  2. Rob20
    Rob20
    Jul 3, 2004
    3,132
    +675
    If you had a USA GC I'd say get a component lead and take advantage of the progressive scan mode enabled in some GC games such as MP and Burnout 2. As for UK GC, probably RGB is the best lead.
  3. MarTTy
    MarTTy
    Jun 10, 2002
    34
  4. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    Thanks guys. I found someone on e-bay selling one of the component cables. Also I was reading on the Nintendo site that as of May 2004 they stopped making the GC with a digital out port! Apparently it allowed them to reduce costs and demand was poor.
  5. t-force
    t-force
    May 2, 2001
    1,855
    Southampton, UK
    +145
    I believe the UK Cube is still made with the digital out port - you certainly should be able to find them even if it isn't. As MarTTY said, go for the component option. For the ultimate performance, pick up a copy of Freeloader (you can find it for as little as £9.99 now, absolute bargain) and get prog scan compatible NTSC games. Yes, the PAL Cube CAN output progressive scan if you treat it right: Component cable + Freeloader + Prog Scan NTSC game = graphical goodness!!
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,343
    Bristol
    +8,639
    Is it true you need to connect up the original AV Cable that came with the Gamecube to get audio?
  7. t-force
    t-force
    May 2, 2001
    1,855
    Southampton, UK
    +145
    Yes, that's right, as all audio comes out the analogue out, not the digital.
