(UK) DVD/DivX Player - Whats the best one for MP3 playback?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hagglelad, Oct 25, 2004.
  1. hagglelad
    hagglelad
    Oct 25, 2004
    76
    +21
    I'm shortly gonna be purchasing a DVD/DivX player on which to play my DVD's and also my vast quantity of DivX vid's.
    I would also like to utilise the player as part of my hifi setup as an MP3 player.
    From the reviews that I've read it appears that the interface's for browsing MP3's on CD (or preferably DVD) are very limited.
    e.g. They can only read the first X chars of a filename + you can't browse MP3's whilst one is playing, + you can only select random on a folder, not the whole disc, etc
    Does anyone know of a player that has a good GUI which makes for easy use of MP3???
    Thanks v much
  2. Spiny
    Spiny
    Jul 29, 2004
    60
    Cirencester
    +4
    A chipped XBox with xbox media centre beats anything else hands down here, although it's not ideal for DVD playback. I'm thinking about getting a Sony 785 or 955 myself.
  3. hagglelad
    hagglelad
    Oct 25, 2004
    76
    +21
    Woah,
    I had not idea that was possible on the XBox !!!
    Does the XBox have to be modded??
    Is this something that thats done quite regularly?
    (presumably it doesn't play DivX's, or does it???)
    Thanks for the tip tho.
  4. hagglelad
    hagglelad
    Oct 25, 2004
    76
    +21
    Sorry what product are you refering to when you say "Sony 785 or 955"?
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    chipped xbox plays every type of media file you can get in the drive
    MP3, xvid, wma, divx, dat, mpeg, etc (and any region dvds)(may not play DVD+R media)
    or if you can live with the filename restrictions then the DK Digital 915 dvd player
    from ebuyer.co.uk costs £52 delivered and is really good (cr@p remote tho, works but looks naff) and can also play any media files the xbox can
    I have both, and they are great.
  6. t@xman
    t@xman
    Aug 23, 2002
    350
    +19
    Xbox is great for media centre, but it's bloody noisey! I got me a SONY DVP-ls985 for £110 today and so far it's rather great! Does DivX, SACD and Progressive Scan....it's a pretty box too and goes marvellous with the matching lv500 receiver that EmpireDirect have reduced to £66 atm!
  7. The Penetrator
    The Penetrator
  8. IanJF
    IanJF
    Would you happen to know if the 915 can random-play a DVD R with say 450 MP3 files on it?
    I'm looking for a cheap "jukebox" solution for our cafe so that we can put one disk in of a morning and leave it playing all day for say 14 hours without having to touch it again. We'd like to keep our CDs safely out of harm's way and keep the place a bit tidier too.
  9. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    the 915 can only play tracks in 1 folder, in order
  10. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    Can anyone comment on the 915s ability to play Divx / Xvid from DVD-Rs? The website lists the following compatibility:
    DVD / VCD / CD / CD-R / CD-RW / MP3 / SVCD / HDCD / Foto CD/ xVID / DivX versions 3.11, 4.02 and 5.1
    I want one for the girlfriends place so I can watch decent stuff whilst at her place (she only has 4 terrestrial channels, which makes going to her place a little like going cold turkey compared to my setup!).
    Xav
  11. Spiny
    Spiny
    Jul 29, 2004
    60
    Cirencester
    +4
  12. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    I agree that the Xbox is superb once it is networked, but depending on your intended uses, I believe that you can replace the DVD drive with any PC DVD drive and it will then play anything (CDRW, DVD RW +/- etc) apart from original Xbox games. If you want to play Xbox games, you will need a Samsung 616T (http://www.divineo.com/cgi-bin/div-us/xb-616t.html).
    Personally, I load all my backups to the XBox via the network, so the DVD drive is only used to play original DVDs.
  13. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    my 915 plays xvid and divx of every sort from dvd-r, dvd+r, dvd-rw, dvd+rw
    so far anything I can play in my PC will play in the 915.
  14. Spiny
    Spiny
    Jul 29, 2004
    60
    Cirencester
    +4
    Presumably you mean a 785? Does it play Xvid & how is it with DVD-Rs?
  15. hagglelad
    hagglelad
    Oct 25, 2004
    76
    +21
    Just to update you all on this one....
    I went out and bought an Xbox especially for its media centre and I have to say...
    ITS ABSOLUTELY F**KING AWESOME....
    I've installed a 160GB hard disc in it and its immense. It plays every type of media you could imagine, will stream Radio AND TV off the internet, downloads weather forecasts, steams movie and games trailers, I can copy games no problems, play on xbox live for free, the list is endless.
    Seriously if you've got an xbox, chip it, if you haven't buy one (i did)!
    Check out:
    http://www.xbox-scene.com/
    http://www.xboxmediacenter.com/
  16. dave_bass5
    dave_bass5
    Jul 6, 2004
    6,715
    London, centre of the universe
    +625
    I have the DK-digital 339. its more or less the same as the 915 but very slim.
    Yes it plays most file types from most types of disc including dvd+r/w, dvd-r/w.
    but it WONT play .wmv or Quicktime files (AFAIK) so all the people who say it plays all the files their pc plays need to check this out first. it plays .wma which is audio only.
    Its a very good player and a great price from ebuyer.
    Dave.
  17. timp
    timp
    Jun 26, 2003
    71
    South Coast UK
    does anything (off the shelf) play .wmv's then? Any of the Kiss players?
  18. dave_bass5
    dave_bass5
    Jul 6, 2004
    6,715
    +625
    i think there are a few.
    have a look at www.videohelp.com, they have a list but im not sure how up to date it is and wether we can get the player here in the uk
    Dave.
