why? because neither my TV nor aerial socket on the wall have f-connectors.
i can buy a pre-made cable with the correct connectors.
i have no desire to make my own cable, not add convertors to any cable to turn it into the connectors i need.
More fool you
hello, i am currently re vamping the living room,home cinema,tv on wall hidden wires etc.i have 2 runs down inside the channeled out wall, 1 to tv aerial & 1 to freesat,then a further 3 runs down 2 to twinsat receiver & 1 to fm aerial on home cinema amp,so 5 runs down in total.my questions are...
www.avforums.com
The Bellin lee connector was designed to copy with RF frequencies way below the IHF band and the satellite IF frequencies higher than the UHF band
It dates baclk to 1922.
t was invented at Belling & Lee Ltd in Enfield, United Kingdom
[a] around 1922 at the time of the first BBC broadcasts. Originally intended for use only at MF frequencies (up to 1.6 MHz) when adopted for Television they were used for frequencies as high as 957 MHz. Belling Lee Limited still exists as a wholly owned subsidiary of
Dialight, since 1992.
[2]
Suggest you stop wasting our time. All the connections in my extensive setup use f connectors.
Where converters are needed, They are much hiigher quality than the cheap Belling Lee ones, that are usually incorrectly fitted/.
High quality triax masthead amplifier kit
Do you see any Belling lee connectors
Wolsey LTE Masthead Amplifier Kit F-Connector Masthead Amplifier and Power Supply Kit 1 Input 4 Output 10-25 dB Variable Gain Weatherproof housing Fully scr...
www.triax.uk
etc etc
Stop wasting our time.
It;'s really simple to make up your own using high quality cable. It will perform much better than any expensive cable you buy.
Yo have no idea as to the performance of the cable used.
WF100 cable specs
Coaxial Cable Specifications WF100 CT100 WF65 RG6
www.satcure.co.uk
If you want the best aerial for most it uses F connectors
the best for most
www.aerialsandtv.com
Discover the premium quality of Webro's WF cables, designed for superior signal transmission and long-lasting durability. Contact us at 0115 972 4483 for UK-wide delivery of these excellent connectivity solutions."
www.webro.com
Why did you ask if you have such stupid ideas in the first place.
Clearly you haven't a clue.
If you can't be bothered to listen to advice based on actual experience, stop wasting our time,
