UK adaptors for US bought I-POD MINI
Discussion in 'Headphones, Earphones & Portable Music' started by FIZZBIN2003, Mar 10, 2005.
  1. FIZZBIN2003
    FIZZBIN2003
    Jan 15, 2004
    231
    North London
    +4
    Anyone know where I can get the adaptor required for the powerlead for a mini I-Pod bought in the US?
    I think that Apple have a Universal Adaptor set but that's about $40 which seems a lot.
    Is there a cheaper option and can I pick this up in PC World or Dixons etc.?
    Also what exactly should I be asking for?
    Grateful for any advice.
  2. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Fizz,
    As far as know if u buy a uk/US plug converter, it will work with the ipod!!
    the firewire cable should regulate the power 4 u
  3. FIZZBIN2003
    FIZZBIN2003
    Jan 15, 2004
    231
    North London
    +4
    Thanks for the advice Hughsey! :)
    I do also have an i-Mac (though it's several years old) and I think that I might even be able to charge up the battery through connecting the two up? Which would mean I wouldn't need an adaptor.
  4. MagicBoy
    MagicBoy
    Sep 19, 2003
    306
    +21
    You can charge the battery either through the firewire connection, or by connecting the firewire cable to the AC adaptor. My 3G iPod charges quicker from the AC adaptor.
    I also got mine from the US. I removed the US plug from the AC adaptor and found a 2 pin figure of eight socket like you'd see on most home audio equipment behind it. A standard lead works fine when connected to it for me - total cost = nil :D
