Do you actually want HDR10+?
Well, obviously!
I mean, if I get a player that doesn't, we all know EXACTLY what will happen...
And the UB820 in almost the same price range. While price of the UB450 isn't firm yet, around £250 seems likely at first.Do you actually want HDR10+?
If so the Panasonic UB450, it's the only player covering all three current HDR formats and one digital audio output and twin HDMI.
Not obvious as no one is really supporting it. As you do the answer is above .
Speak of the devil.UB820 available on Ebay with 20% off, from Hughes £231.20 offer ends 4th.
Sony X700 also available on the offer.
The joke was, as soon as I decide to buy a player without it, it'll become the de facto standard for every disc (particularly my favourite films), with everyone saying they look fantastic, but only with HDR10+.
That aside, if that's not supported, what's the best (again, cheapest) without.
Cheers.
The Sony X700 with the 20% ebay code bringing the price down to £147.20 delivered is the best deal you'll get at the moment if cheapest, decent enough, player is what you want.Sony X700 also available on the offer, less fancy bits and no HDR10+.
Sony UBP-X700B 4K Ultra HD Blu-ray Player 4548736062764 | eBay
It nicely beats the LG UBK90 on price (£159.20 with ebay code at Crampton and Moore) and more crucially is a much better player.
Indeed...Panasonic are currently the only manufacturer to be supporting HDR10, Dolby Vision and HDR10+. If wanting to portray all three then you'd also need a Panasonic TV.
I don't think HDR10+ would ever become the standard for disks, although Samsung would like it to be the standard. Amazon, on the other hand, has adopted it and a lot of Prime content is available with HDR10+.The joke was, as soon as I decide to buy a player without it, it'll become the de facto standard for every disc (particularly my favourite films), with everyone saying they look fantastic, but only with HDR10+.
Cheers.
If all you want to do is spin discs (DVD-A and SACD excepted) the Panasonic is fine.Any reason not to go with the Panny?
All media players have limitations of one form or another (even the OPPO's). Ultimately it depends on what features you require....
OKay, zombie thread revival.
I'm now ready to drop c.£200 on a player at Amazon.
The Sony 700, 800 and the Panny 450 are all just a few bob either side of that budget.
According to Panasonic's mantra... This should be the other-way round...Panasonic is about features, not image quality.
If you want a reference player that dont mess up your source material, just passing a unmolested chroma and luma signal without backdoor processing the Panasonic UHD players is a no go, if that dont bother you, it will do fine.
Really?
First I've heard of that.
There's no review here for this model, but there is for other Panny UHD players, as well as owners threads, and I don't remember reading anything.
Its a chipset limitation in the Panasonic players that has been ther since the UB900, HDTV test mentioned it brifley in the UB9000 test, anyway its easy to test if you have a few basic testpatterns.
The only thing Panasonic can do is tonemapping, they are the best at that, every other parameter is medium to poor. No matter wich Panasonic UHD player you pick.
Most people dont notice it, just be aware if your going for reference image the Panasonic is not it in terms of unmolested disc playback.
Vincent said a lot of stuff about Panasonic UHD players, funny is he mention the chroma issu in the UB9000 review, but the issue has been presented on all Panasonic UHD players.Vincent Teoh of HDTVTest also mentioned in one of his videos that Panasonic players output image perfect pictures, with no changes from what is on the disk. Conversley, I did read a Which.co.uk review that said the Panasonic DP-UB450 wasn't very good. So which UHD players do you think do things well?
