Hi, I'm moving into a new house within the next few weeks and want to get as many wires in place before I start decorating.
The heart of the system will be my 'cinema room' which I'm going to set up for Atmos using my Denon AVR-X2300, this will be located in a bench under the TV with the rest of my equipment, SkyQ, A bluray player and apple TV.
Also in the house will be a TV in my main bedroom and another 4k TV in the living room, both with sound bars.
It has been suggested that I can buy a matrix which I can put with all the equipment so that rather than get sky multiroom and multiple bluray players and apple TV boxes I can just use the ones which are downstairs in my cinema room.
I would like to have a level of control which made it feel like these were in the room with me. I also like the idea that there will be no wires visible as I can plaster over them
My initial searches have led me to the hdanywhere Mhub, is this suitable for what I want? What other systems could I look at?
Am I right in thinking that the only wires I will need within the wall are an ethernet cable and the IR extenders? Is there anything else I need to consider other than the power itself?
Is this the best way to do it or are there other options I should consider?
Richard
Richard
