UHD 10m HDMI - JVC Projector
Discussion in 'Projectors, Screens & Video Processors' started by stevos, Jun 10, 2019.
  1. stevos
    stevos
    May 16, 2004
    6,213
    +593
    Does anyone have a recommendation of a longer HDMI cable that works with a JVC projector.
    It seems my existing 10m cable works fine with my LG OLED but not my projector, so i assume the JVC HDMI board is less sensitive.
    Ideally looking for one in white.
  2. Superhans
    Superhans
    Sep 29, 2007
    50
    11
    Manchester
    +24
    When I installed my X7000 I put 2nr 18GB cables in a closed up false ceiling. Worked fine with 1080p but absolutely failed at 4K. Cables about 7.5m.
    Only thing that consistently worked is a 10m Ruipro. Not cheap though and I don’t know about white.
  3. stevos
    stevos
    May 16, 2004
    6,213
    +593
    Brought another cheap cable that is meant to be rated to work. If that fails, I will try a redmere cable and failing that explore ruipro
  4. TimC
    TimC
    Oct 31, 2017
    112
    32
    Hitchin
    +45
    I went for a monoprice optical hybrid cable (like the ruipro) from Amazon in UK. Was a bit cheaper and works perfectly at full uhd hdr 60hz 12 bit across 15m.
    I think these are the only options really guaranteed to work so would personally avoid wasting money on alternatives that may not.
  5. jakimp
    jakimp
    Feb 21, 2009
    1,458
    2
    116
    bromsgrove
    +1,220
    10m ruipro works perfectly with my N5 on all 4k HDR sources
    think fibre optic is the only reliable answer but
    £100+
  6. Amar
    Amar
    Apr 15, 2005
    1,155
    63
    +106
    I just got an Amazon basics HDMI. 15m. Working fine so far.
  7. jakimp
    jakimp
    Feb 21, 2009
    1,458
    2
    116
    bromsgrove
    +1,220
    are you using a 4K disc player? if so you have done well with that cable and saved a lot
  8. Amar
    Amar
    Apr 15, 2005
    1,155
    63
    +106
    Using the nvidia shield tv. Seems ok so far. Hopefully, it lasts.
  9. jakimp
    jakimp
    Feb 21, 2009
    1,458
    2
    116
    bromsgrove
    +1,220
    great - I had doubts that my oppo 203 playing a UHD disk would work over 10m to a JVC N5 without going the fibre route so I bought a ruipro
  10. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    Most non fibre cable will struggle if you push the PJ to it's max, i.e. 18gbps / 4k @ 50/60hz with HDR etc. I've tried so many longer 10-15m copper cables including a number of active redmere and non I tried would consistently do it properly with the JVC. I've even tried 2 x 5m with an hdmi splitter in the middle to boost, but had limited results.
    It may be a hard pill to swallow, but you're really best not scrimping, especially if the cable is awkward to change later. There are a number of good quality fibre cables available today as it is no longer a niche requirement, just buy from a reputable seller with good returns policy, I'm a Prime member so hence was happy to buy a few and try them etc.
    Problem is with non-fibre cables of say 10m you may believe the manufacturers claims and think you've gotten away with it, but there's a reason why tested hdmi certified premium cables aren't available over 5m, they simply can't pass the bandwidth test.
    If a non-fibre cable works for you it may just be you don't watch content that actually requires 18gbps 'YET'. Content like [email protected] 4:2:0 8bit without HDR or [email protected] 4:2:2 10/12 bit with HDR only require 9gbps for example.
    A full table can be found at the bottom of this article: HDMI Data Rates for 4K HDR
    If your device or content however is outputting 4k @ 50/60hz AND HDR you will need 18gbps and most non-fibre cables will struggle. Often 4K Film and TV content these days is only 24hz so you may be blissfully unaware, but something like After Life I think should be 4k @ 50hz with HDR and should test things as does 4k gaming consoles and nVidia Shield if set to output at 50/60hz.
  11. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    Sounds promising! :smashin: Do you know if you're using HDR & 50/60hz? What's the JVC info screen say.
  12. Amar
    Amar
    Apr 15, 2005
    1,155
    63
    +106
    Pretty sure mine says the same but will double check tonight and post my findings for you.
  13. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,113
    +483
    fiber cables at amazon are now also reasonable priced ie under £45
  14. stevos
    stevos
    May 16, 2004
    6,213
    +593
    The part I don't get is why it works fine on my TV. Wondering if a cheap hdmi signal booster might work, but I'd there is a 4k fibre cable for £45 I will for sure go that way if the new cable doesn't work.
  15. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    JVC is a bit picky for perfect signal, had a DLP 4k temp whilst waiting for JVC to arrive and that was 100% fine. Think the signal was not good, I.e. it would not pass an 18gb certified test, but it was good enough to get away with it. I did use it temporarily with SkyQ and the JVC whilst waiting for fibre to arrive (nVidia wiyld not work at all), but then when a mate came to see it he asked me what the sparkly white things were! New fibre cable same, nVidia worked fine and SkyQ sparkles also gone.
  16. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    Think you may also find it hard to find a ‘cheap’ 4k 18gb signal booster, I tried 2 or 3, including a linker before I discovered fibre hdmi. Fibre hdmi is the right way to go. You wouldn’t buy a brand new Ferrari and stick cheap tyres on it as the guys selling the cheap tyres told you they’d do the job fine?!?
  17. stevos
    stevos
    May 16, 2004
    6,213
    +593
  18. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    I had that exact same cable and didn’t work for me at 10m. What resolution, bit rate and hdr settings are you using? Have you tested a 4k @50/60hz hdr source?
  19. stevos
    stevos
    May 16, 2004
    6,213
    +593
    Xbox One X using its menu and then a UHD BD of Martian.
    So far works fine, but only had time to test for about 5mins, will report back if continues to work.
    I have the following cable sat on my amazon wish list, just in case
    https://www.amazon.co.uk/dp/B07M6N5DV4/?coliid=I2KOM999NGFRLC&colid=GED7DFM6C47K&psc=1
  20. stevos
    stevos
    May 16, 2004
    6,213
    +593
    p.s. also now tried skyq HD, which is outputing 4k50 at 10bit.
  21. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
  22. stevos
    stevos
    May 16, 2004
    6,213
    +593
    I haven't got time this week to watch anything of length but plan to watch a movie over the weekend, will be interesting to see if it can keep a signal for the full duration.
  23. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    Fingers crossed for you :thumbsup:
  24. Amar
    Amar
    Apr 15, 2005
    1,155
    63
    +106
    My results on a X5000 using an Amazon basics cable. Hope it helps.
  25. stevos
    stevos
    May 16, 2004
    6,213
    +593
    The white cable i linked above works perfectly, zero issues so far.
  26. Toobad
    Toobad
    Oct 16, 2007
    77
    Hereford
    +46
    That white 10m CSL cable from Amazon struggled linking my Denon X4400 AV receiver to my Optima UZ65 laser projector. It would pass [email protected]+HDR after struggling to find the source. Then consistently it would drop the source about 55 minutes into any 4K UHD Bluray film. It would then hunt and resume in 1080p for around 4 minutes before dropping out again and then finding the 2160p signal. Perhaps there is extra data associated with a layer change on the UHD BD that makes it bail so consistently. If I put the Denon into enhanced mode to pass [email protected]+HDR from my Xbox One X, the projector will not resolve the signal.
    The price for that 15m Shuliancable fibre optic hybrid cable kindly linked above by @Thatsnotmynaim is sufficiently cheap at £31.99 (or maybe less as I went through Topcashback) to be worth a tickle so I have now pulled the trigger on that. Watch this space.
  27. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,314
    137
    Middle Earth
    +858
    I think an element of the success is due to all bits of kit in the chain, so source, amp (if you have one) and display etc.. I had an amp in the chain (Arcam and also tried Denon & NAD) and had issues. It’s possible that different setups have less/different issues. A non fibre will struggle to transmit 18gb cleanly hence why they do not get certified. A particular setup may be able to get away with that however, but I think a fibre or other active setup is the most reliable in terms of results and technical ability to transmit 18gb. At the lower price they appear to come at now, it’s not that much an investment any more. Be aware that with some setups especially with amps with multi monitor out, when used with a TV and a PJ you can get off HDCP handshaking issues, when using the non fibre display. Denon/Marantz amps can turn on/off each HDMI out, but other amps can struggle.
  28. stevos
    stevos
    May 16, 2004
    6,213
    +593
    HDMI is such a naff technology, they focused too much on copy protection and not enough on future proofing. Why on earth is there a different data feed for hdcp and the video, why is it not just transferred in packets like network cables have been doing for decades.
    For sure i would recommend just going for the fibre option, as they aren't that much more expensive and should be more reliable and thinner but for me being white was key as i don't have it channeled in the wall.
  29. Toobad
    Toobad
    Oct 16, 2007
    77
    Hereford
    +46
  30. LotusElan
    LotusElan
    Dec 20, 2002
    3,760
    103
    +386
    We bought a 15m version of this fibre optic cable as we were having random black flashes on the TV (diametrically opposite to the amp in the room hence the need for a very long cable). Came very quickly and seems at the very least adequately constructed. And currently there's even a further 5% off voucher to save another couple of quid.
    Was a little bit sceptical in case it was going to be yet another "emperor's new clothes" purchase but it's been flawless for the 6 months it has been installed. :)
