UFC BTS2 recording issue
Discussion in 'Cable TV & Virgin Media TV' started by jm28cardiff, Aug 18, 2013.
  1. jm28cardiff
    jm28cardiff
    Dec 2, 2006
    143
    +7
    I watched UFC main event just now, but when I went to watch the prelims I had also recorded, an error came up saying the recording was from a channel I wasnt subscribed to (I am on XL). In the recordings list, the channel showed as "unknown". Anyone else have any problems like this?
  2. Mashburn
    Mashburn
    Jul 18, 2010
    458
    +46
    Yes. I had the exact same problem on my v+ box. My TiVo box, however, recorded the prelims without a problem! :confused:
  3. blueboy1971
    blueboy1971
    Nov 18, 2007
    1,066
    48
    +81
    Just remembered that this was on and what a surprise, the series link on my TIVO did not record it. Useless machine
  4. ozsat
    ozsat
    Apr 8, 2006
    963
    28
    Oxford, UK
    +76
    What channel is your series link on ?
  5. dante01
    dante01
    Mar 5, 2009
    45,613
    +10,853
    It could be that some of the content that is aired via the BT Sports channels is copyright protected and if this is the case then you'd be unable to record it. This is down to the channel provider and their use of HDCP as opposed to being something implimented or controlled by Virgin Media. The fact that both the V+ and the TiVo exhibit this behaviour goes some way to confirm this to be due to copyright protection implimentation as opposed to it having anything to do with the hardware being used by Virgin customers.
    Both SKY and native BT users also report issues when attempting to record UFC content.
    http://thesportshub13.com/2013/08/1...dia-ufc-fans-witing-it-out-over-ufc-blackout/
    It is reported that UFC content will become recordable within the next few months.
  6. ozsat
    ozsat
    Apr 8, 2006
    963
    28
    Oxford, UK
    +76
    UFC record fine on TiVo.
    The problem was that less than 1 hours before transmission - the moved it from Sports 1 to Sports 2.
    Those whose TiVo didn't update in time - recorded Rugby.
    Those with a wishlist for UFC and that had received the update - had UFC record fine.
