Can someone just confirm if the UE43NU7470 has va panel?
I’ve found a 01/ version for sale and just want to make sure it is 100% VA before buying.
And is there any differences from UE43NU7470 to UE43NU7400?
@desinho might know, as for differences I think the 7470 is solely IPS now, no VA panels are being used for this model but not 100% sure.
Entering the service menu will give you a definite answer.
Samsung revise models twice over a year, most of the time they are normally just cosmetic like bezel colour etc or additional features like sat tuners but they also change the panels as well, it's hit and miss with them.
All the 01's should have the same panel afaik (so in this case the VA yes). Maybe you can check what the serial number is as well, see this post: 40/43” with Wide Color Gamut? (VA aswell would be perfect)Now I’m really confused because I know the 01/ versions on UE43NU7400 are VA, so I thought it would be the same for the 01/ versions of the UE43NU7470
Hoping @desinho can help.
Thanks for the reply.
