UE32T5300 and Panasonic SC-HTB200
imrana
Hi All
Looking for some advice, have a Samsung UE32T5300, with a Panasonic SC-HTB200 sound bar connected via HDMI. 20% of the time, the TV wont turn on the soundbar, I have to get up and press the power button on the soundbar, 80% of the time when I turn the tv on (via sky+ remote) get a message top right hand side of the screen, saying:-
Receiver (HDMI) Your audio device is connected to a port that does not support ARC. Please connect your device to the HDMI 2 (ARC) Port.
Thing, is the soundbar IS plugged into the ARC port otherwise it wouldn't turn of and on, had the tv reset via samsung remote help. Had the HDMI ports reset, firmware was 1403.1. In the end ended up swopping the Tv for a replacement, replacement TV has firmware 1410, and its showing exactly same message, tried multiple HDMI cables from cheapo to expensive, annoying thing is the soundbar works flawlessly with the Panasonic GX800 downstairs.
Now ringing Argos to try and replace the soundbar, any ideas? anyone else have this same hardware setup?
65-inch LG C1 Review coming soon to AVForums
