Overview
* This release requires 1.9.x or newer on the UDM-Base/UDM-Pro.
* This release requires 0.4.x or newer on the UXG-Pro.
Improvements
- Add port remapping for UDM-Pro.
- Add Device/client icons in alerts.
- Add redirection button to settings in Alerts page.
- Add ability to reset statistics.
- Add Data Retention to search.
- Add Multi-Site Management toggle.
- Add Debug terminal in New Devices page.
- Add a banner in Beta Settings to allow reverting back to Classic Settings.
- Add Wifi, Hotspot, and AP Group membership overview info in property panel of APs.
- Add USW Mission Critical Property Panel outlets tab in New Devices Page.
- Add 2.4GHz and 5GHz icons, updated translations.
- Add Gateway info to left panel on new Dashboard.
- Add validation to ISP Capabilities.
- Add missing Network Scanners in Security Settings for UXG.
- Add new Insights page.
- Add new Topology page.
- Add new Statistics page.
- Add Statistics per client usage
- Add WPA3 support (for AP devices that support that*).
- Add WiFi Scanner section on Insights page.
- Add Advanced Feature Toggles, Data Rate Controls, MAC Authorisation in WiFi form.
- Add a title, remove the wired filter, update column titles on Clients page.
- Add pagination buttons to WiFi Scanner and Alerts pages
- Add filters to Clients Page.
- Add USW Mission Critical overview tab.
- Add ports tab in USW Mission Critical property panel.
- New Implementation and behaviour of WiFi Scheduler.
- Remove WiFi Scheduler classical settings since the old scheduler does not support showing multiple events per day.
- Do not show EOL/LTS notifications if user has dismissed them.
- Exclude MS Edge from unsupported browsers.
- Ensure FlexHD has the correct image.
- Show limited Dashboard for Software installations of NET controller
- U-LTE-Pro configure section in property panel.
- Display Site Switcher if Multi-Site Management is enabled.
- Improve the responsive layout of the statistics page.
- Update layout of action buttons in tables.
- Updates for Alerts page.
- New Alert for AP radar detection.
- Support static IP users in L3 networks.
- Improve validation of MAC Address for the MAC Address Cloning feature.
- Open Account Edit form if user is required to change password.
- Clients property panel UX updates.
- Tweaks to dashboard and settings survey.
- Remove "beta" badge from Threat management in legacy settings.
- Add WiFi, Hotspot, Network, Internet definition fields to search.
- Increase default row count in pagination to 25.
- Hide SSID Antenna count circle in Insights page if it is not expandable.
- Disable by default "Unknown" traffic in the statistics page.
- Update description text for WiFi AI.
- Update device images within topology page.
- Update appearance of property panels for switches.
- Update appearance for popovers in statistics sorting section.
- Update mouse pointer appearance in clickable table rows.
- Update port diagram and table styling for SFP+ ports.
- Update and define default columns in Clients page.
- UX Updates in Statistics page.
- Decrease the refresh interval in new sections to 5s.
- Add real-time updates to Alerts page.
- Add new Alert when Client cannot acquire IP address.
- Add auto-scroll to a form validation error upon trying to submit an invalid form.
- Add WiFi Experience tooltips.
- Performance optimization for alerts page.
- Clear Settings Search upon leaving Settings page.
- Display labels instead of exact firmware versions in clients page.
- Copy updates in Settings.
- Send alert emails.
- Move WiFi AI section to Advanced Features.
- Mark alerts as read upon viewing them.
- Display Site Switcher on Cloud Key with UniFi OS and multiple sites.
- Display the WiFi Security Protocol field even if there is only 1 option available.
- Improve client & device names for new alert Push Notifications.
- Improve filter on Devices Page - filter rework.
- Improve readability of error messages in Ubiquiti Account login modal.
- Improve topology label appearance on Safari and Firefox.
- Improve Error page.
- Enable new alerts page & Add toggles to enable it in Settings.
- Combine Radio accordions into one in property panel of AP.
- Remove Unknown from Most Popular Apps on new Dashboard.
- Remove empty placeholders in Most Active clients on new Dashboard.
- Remove lightning icon on Devices Page.
- Remove link to help from left Navigation.
- Rename Strict mode to Interference blocker.
- Rename term "Elements" to "Devices".
- Rename Client Groups to Bandwidth Profiles.
- Update AP property panel in New Devices page.
- Update "Learn More" URL for access points.
- Update layout and content for property panels in Clients page.
- Update Overview fields for U-LTE devices.
- Update Settings Maintenance page.
- Update gridlines in the graph on Dashboard page.
- Update Experience column on Device page.
- Update Clients page.
- Update colors in new statistics page.
- Update icon in "Add Client" window.
- Update Clients table in device property panel.
- Move client icons from Pie to Table on new Dashboard.
- Move Radio Meshing section to last of APs 5GHz radios on Devices page.
- Expose Advanced Features and Remove "Enable advanced features" checkbox in Classic Settings.
- Adjust Property Panel for USP - Power Distribution Unit Pro.
- Adjust left side section on Dashboard page.
- Hide the Threat Management icon from the left Navigation if Threat Management is disabled.
- Disable ATF toggle for devices that do not support it.
- Close all property panels whenever user navigates to a different section.
* WPA3 supported models (5.43+ FW):
UAP-AC-Pro, UAP-AC-Lite, UAP-AC-LR, UAP-AC-EDU, UAP-AC-M, UAP-AC-M-Pro, UAP-AC-IW, UAP-AC-IW-Pro, UAP-AC-HD, UAP-AC-SHD, UAP-XG, UWB-XG, UAP-nanoHD, UAP-HD-IW, UAP-FlexHD, UAP-BeaconHD, U6-Lite, U6-LR
Bugfixes
- Fix USP Plug property panel.
- Fix shown Passthrough and External Antenna values for ULTE-Pro.
- Fix incorrect data limit fields and their values for ULTE-Pro.
- Fix spacing issues within Property Panels on Safari.
- Fix broken positioning for Port Profile Storm Control warning icon.
- Fix validation of ISP Provider Capabilities in Internet section.
- Fix Delay in Dashboard WiFi widget after removing all APs.
- Fix incorrect modal for usage in cloud controller during LTE setup.
- Fix icons of most active apps exceeding available space.
- Fix some narrow images appearing stretched.
- Fix Internet Settings and Ports accordions in property panels causing page crashes.
- Fix incorrect WAN information appearing in "Internet" section.
- Fix page crashing after UAP-nanoHD setup.
- Fix issues with port diagram for UXG Pro.
- Fix being unable to configure bandwidth profiles.
- Fix provision of VLAN only networks on UDM devices.
- Fix model name format for Device Alerts.
- Fix UCK Image being squeezed on Safari.
- Fix a typo in error screen.
- Fix USG uptime shown when devices is disconnected.
- Fix missing WiFi experience reports in the history tab of Clients page.
- Fix appearance of Client name from alias.
- Fix clients page crashing when trying to open Property Panel
- Fix inability to save WiFi radius settings.
- Fix topology nodes overlapping the tooltip.
- Fix issue that RF Environment results are visible only after changing tab.
- Fix saving POE Mode "Do not modify" in Switch Port Profile on New Devices Page.
- Fix the empty form on auth and acc server forms.
- Fix timezone related runtime error causing crashes in New Dashboard.
- Fix missing clients on Dashboard.
- Fix missing logs in UCK support file.
- Fix uplink for USP devices.
- Fix Deferring to WLAN user group.
- Fix event message rendering.
- Fix models names for APs.
- Fix configuring fixed IPs on New Clients page with UXG-Pro.
- Fix mandatory setting of the PoE mode at Port Profiles on Devices page.
- Fix DHCP Name Server is not properly saved in New Settings.
- Fix broken Port Table on Devices page.
- Fix provisioning WLAN changes for USP-Plug & USP-Strip and their uplinks.
- Fix adoption of USP-Plug & USP-Strip if the user has separate 5GHz only WiFi.
- Fix issues during migration if Site has an incorrect config.
- Fix Unknown device names in Cloud Emails.
- Fix issues with migrations to 6.1.
- Fix Firmware Cache table columns and heights.
- Fix overlapping column headers on the Alerts page.
- Fix size of icons on the Clients page.
- Fix broken links on the Devices page.
- Fix the behavior of filters when navigating across different pages.
- Fix default channel width value for Radio dropdown in Property Panel.
- Fix Property Panel for USP-Strip.
- Fix links for most active clients in new dashboard.
- Fix the same toast message being shown multiple times.
- Fix disconnected devices not showing details in devices page.
- Fix headings for UDM-Base and UBB radio details.
- Fix inability to save VLAN ID toggle for Internet Settings.
- Fix broken spacing in "Login with your Ubiquiti Account" window.
- Fix not all LAG ports showing up as uplink in Devices page.
- Fix property panel appearing empty for offline devices.
- Fix tooltip positioning.
- Fix real time data not getting updated in the new Controller frontend.
- Fix GHz spelling.
- Fix the handling of duplicate IPs.
- Fix the "Experience" label for wired clients in property panel.
- Fix showing no client if the wifi experience is 0.
- Show device alias in client grid if it's available.
- Prevent runtime errors in Internet section.
- Prevent showing wifi experience over 100%.
- Use device display names for User AP roaming notifications.
- Update the URL for "Learn More" link in "no WiFi experience" section in New Dashboard.
- Update the width of experience column in clients page.
- Avoid showing higher utilization than 100% in property panel.
- Make an order of Radios in the Property Panel consistent.
- Allow toggling Guest Portal for Hotspots in Hotspot form.
- Allow configuring USP devices which were adopted in versions older than 5.14.
- Show WiFi experience as N/A if no clients are connected.
- AP Radio advanced configuration adjustments.
- DNS server now can be deleted from WAN form.
- Suppress events without proper handling.
- Do not expose SSID for Element Adoption
- Reset channel on channel width change in Property Panel.
- Update default state for AP Meshing.
- Migrate minimum RSSI settings to new range (from -67 to -90 dBm).
- Update UI for WiFi form in Advanced section on Settings page.
- Display Interference Block toggle only if Minimum RSSI is enabled.
- Display "Auto" as the default selected option in AP Uplink Priorities.
- Display Meshing settings only for last of 5GHz radios.
- Resolve migration issues for users without DHCP Snooping setting in controller database.
- Ensure correct device image appears in the property panel on Devices page.
- Ensure Port Names match numbers on the physical device on the Devices page.
- Prevent deletion of WAN2 network on UXG-Pro.
- Prevent login loop.
- Resolve UCK-G2 identification issues.
- Disable Bluetooth after Setup completed on UDM-Pro.
- Add advanced configuration options for Alerts in new Settings.
- Correct validation of VLAN-only networks limit.
- Filter out UBBs from clients list.
- Remove the incorrect link for the version number text in new settings.
- Rectify the features available for USW-Flex-Mini.
- Display Site Configuration section in settings for Cloud Keys and Software Installations
- Add validation to prevent duplicate WAN network groups from being created.
- Show legacy login to temporarily mitigate login issues with the new (React) login page.
- Disable 'Enable Meshing' and 'Uplink - connect to other AP' options for wireless APs in the legacy app.
- Disable VPN settings when L3 switch is used as a gateway.
- Property panel bug fixes for devices in adopting state.
- Rename "Devices" page to "UniFi Devices".
- Remove LTE/WAN Backup toggle for VPN Networks.
- Remove Auto IPsec VTI option for UDM/UXG devices.
- Avoid showing empty popovers in devices page.
- Hide LTE WAN Backup when LTE is not adopted.
- Update ULTE-Pro Data Usage value system.
- Display correct active client count for WiFi configurations on UDM setups.
- Exclude USP devices when calculating WES score in Dashboard.
- Verify email invite link and load the new UI for new user.
Additional information
Please report any issues you encounter with this release using the Report Bug form.
(Recommended) - Create an up-to-date backup before upgrading your controller in the event any issues are encountered.
- Existing UniFi Network controllers must be on one of the following versions in order to upgrade directly to this version:
6.1.51 and earlier 6.1.x versions.
6.0.45 and earlier 6.0.x versions.
5.14.25 and earlier 5.14.x versions.
5.13.33 and earlier 5.13.x versions.
5.12.72 and earlier 5.12.x versions.
5.11.52 and earlier 5.11.x versions.
5.10.27 and earlier 5.10.x versions.
5.9.33 and earlier 5.9.x versions.
5.8.30 and earlier 5.8.x versions.
5.7.28 and earlier 5.7.x versions.
5.6.42 and earlier 5.6.x versions.
Most earlier versions are also supported for direct upgrade, going back to 3.1.0.
- Controller updates may cause your adopted devices to reprovision after controller upgrades.
- An updated/current version of Java 8 must be installed on the system hosting the controller software. Java 9 and later are not yet supported.
- As of UniFi Network controller 5.9, if using Cloud Access, the host system/device requires outbound 8883/tcp to be open/unrestricted. Find up-to-date port requirements here.
- Minimum supported device firmware for U6-Series devices is 5.29.0, UAP/USW is 4.0.9, and for USG it's 4.4.34.
- If you have any 'service dns forwarding options' configuration defined in config.gateway.json, it will overwrite the provisioning of statically defined name servers, leaving you with no DNS. Either remove the 'service dns forwarding options' portion of config.gateway.json, or add additional 'options' lines defining name servers, such as 'server=1.1.1.1', 'server=8.8.8.8', etc.
