ubergeek question - video+ and panny e50
Discussion in 'Blu-ray & DVD Players & Recorders' started by derb, Apr 27, 2003.
  1. derb
    derb
    Thanks to http://andrewcurrey.co.uk/download/vplus/index.asp I can generate custom videoplus codes for any programme I want to watch including the channel number of my choice. But what "channel number" should I encode to give to my e50 to make it select AV2 (my digital cable box) instead of a terrestrial signal?
  2. bobbles
    bobbles
    When you first record via vid+ to AV2 you have to manually select AV2. After that everytime you Vid+ a non terrestrial signal it will auto select AV2. That is how it works with normal vid+
    That is an excellent little prog
  3. derb
    derb
    [Thinks] If I make all non-terrestrial channels = channel 6 (or channel 666 ;-) then I make that channel = AV2 I may only need to do that once. Thanks for helping me think of that and I hope you and others find that application useful. People without Digiguide (a great little application you should really consider if you are a serious TV watcher http://www.digiguide.co.uk/) may want to visit http://tallyho.bc.nu/~steve/videoplus.html which is a standard Windows program (with source) that generates the V+ codes.
