u73 help
jgrullon
I have a Panasonic TC-P50S1 and a Panasonic DMP-BD60. The bluray player is in my media closet from the closet to where the tv is contractor ran rapid run hdmi cable. In the closet there is Rapid run hdmi active wall plate by the tv a passive wall plate. The directv hr21 works fine but even when I plug the Blu Ray player direct to the wall plate i get the u73 message. If I take the player to the tv and plug it in it works. Can the problem be the wall plate even if directv works well our can it be something else. Help Please
kingfats
My only issue is that the directv receiver works fine through the wall plate
Yeah,that works fine but not the 60 but bypass the wall plate and the 60 works fine direct to TV is that right? it must only point to one thing.
I guess you contact Panasonic see if this is a known issue at all.
jgrullon
Contacted rapid run and found out that the builder did not put in hdmi high speed cable so 1080p is what gives the problem I can view only up to 1080i. If I want full hd would need to run new high speed cable. sucks
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
