U.S. TV in Europe - Help!
Discussion in 'General TV Discussions Forum' started by Toto69, Nov 5, 2003.
  1. Toto69
    Toto69
    Hi there!
    I hope someone can help me...
    I would like to bring a back-projection TV from the U.S. when I move to Europe soon. I know the PAL system is used in Europe as opposed to NTSC in the U.S. However, many TVs do not have tuners installed. Can I buy a PAL tuner and use it with a U.S. TV in Europe? Will I lose picture quality since NTSC has lower resolution, even if it is a HDTV?
    I understand I need a volt converter, but I have now idea about the signals. Can anyone help?!
    Thanks in advance!
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,439
    Somewhere in South Yorkshire
    +5,851
    Without knowing more about the set in question it is difficult to be sure - but it is quite likely that a TV intended for the US market will NOT handle PAL TV signals at all. And converting PAL to NTSC for use in such a set is both expensive and degareds the signal noticeably.
