u.s dvd,s
Discussion in 'Movie Forum' started by ianlecompte, Dec 1, 2003.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    just ordered a u.s version of a film region 1,will this play o.k on a multi region player?or will there be a problem with pal ,ntsc formats?couldnt work out if it was pal or ntsc,any help would be good.i know the region wont be a prob
  2. Dean
    Dean
    Jun 20, 2003
    2,894
    London
    +265
    As long as your TV accepts NTSC it should be ok, otherwise it will be in black and white.
  3. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    yhanks dean,but do most t.vs accept ntsc or not,how do i find out,i bought the dvd for a friend,so if it wont work i,d rather not give it to him,but of course if the only way to find out is to play it thats what i will do
  4. Dean
    Dean
    Jun 20, 2003
    2,894
    London
    +265
    Ian I think most modern TVs should be capable of accepting NTSC but the only real way to know is to check it out. Cheers.
