Tyres
mike.hutch
Does anyone know how you change your tyres when you own more than one type on a car? I've tried the tuning section in the garage and before a race but when I select different tyre types there is no option to fit them to the car.
Any ideas?
supraking
cant remember teh name but its teh white button next to the tuning one before a race
Swordfish
Tried that, it wont let me change even though I own sports and racing slicks for this car.
It will only allow you to change to tyres that are allowed for that event, which is in the settings just before the exit little red man :blush:
mike.hutch
Hmm, I'm pretty sure the races I've been trying are unrestricted, I'll have a look tomorrow. Shouldn't I be able to change tyres in the garage anyway?
Sly Fly
No you cant - just tells you which ones you own.
It's definitely done (or at least I'm 99% sure) just before the race with the tuning or some such function.
cabanatuan
Any ideas?
always use sports:soft tires
Seque
I think you change them in the menu where you select your settings for stuff like Traction Control, Skid Recovery etc, rather than the tuning menu that you change gear ratios etc.
malk
As above says,i learnt the hard way,always i kept forgetting to change,if available,to racing soft.
Its horrible when,you start an online race,nice fast car,people you could really do without being embarressed with,and then first corner,SPANK,right into the tyres...:blush:
