Tyres - Replace in Pairs?
Discussion in 'Motoring' started by Garry123, Sep 10, 2017.
Tags:
  1. Garry123
    Garry123
    Feb 6, 2006
    2,104
    +239
    I had to have a front tyre replaced on my Golf GTD. I am now wondering should I have replaced the other front tyre at the same time? The old tyre has 3mm worth of rubber left. I have only done about 10 mile on the new one.
  2. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,252
    116
    +717
    Not necessarily, if they are both the same brand i.e. Both continental sport contact 5 then personally I'd leave it, if ones a continental and the others a Pirelli I'd change the one with less tread.
  3. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    40,894
    10
    13
    ::1/128
    +14,499
    Oh gosh yes...if the other only has 3mm left, change them both...
  4. Garry123
    Garry123
    Feb 6, 2006
    2,104
    +239
    Same tyre type. I'm going to change it.
  5. mjn
    mjn
    May 24, 2001
    23,732
    Herts, England
    +12,180
    3mm? That tyre is near end of life, especially with winter approaching.
  6. Garry123
    Garry123
    Feb 6, 2006
    2,104
    +239
    Not far off, I suppose. 10k mile, not much mileage.
  7. un1eash
    un1eash
    Nov 14, 2007
    4,978
    2
    +1,407
    Depending on time of year I change my tyres between 2-3mm, New vs 3mm would be a noticeable difference so worth changing both.
  8. ChrisNic
    ChrisNic
    May 11, 2003
    1,989
    63
    Thame
    +135
    One of those things you might not notice until you really need them to deliver in a over cooked it into a corner or need to stop in a straight line to avoid a child sorta way.
    I would definately replace the other one!
  9. Garry123
    Garry123
    Feb 6, 2006
    2,104
    +239
    Replaced it. Thanks for the advice.
