Tyre Sizes
Discussion in 'Motoring' started by OneEyedStuart, Feb 28, 2013.
  1. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,021
    Lockerbie, Scotland
    +937
    OK so I got a new to me car a few weeks ago, one of the reasons I bought it was to save fuel, tax and money on tyres when it comes to changing them
    Went from a Freelander to a Seat Exeo Sport 2.0 TDi
    Anyways... tyres.... was checking prices on the tyres which are on the car at the moment which are 225/45 R17 however when entering my reg plate into black circles it suggests I should be using 220/45 R18
    I know what the numbers are, I just don't understand what they actually mean in the real world.
    Should I be using the recommended size ones? Should I stick with what I have? What's the advantages and disadvantages of both?
    Thanks,
    Keith
  2. Aerojon
    Aerojon
    Jan 11, 2009
    546
    46
    +178
    225 tyre width,45 depth of tyre wall,R17 17" wheel size.. did they no give you a choice of other sizes
    the tyres bc has said won't fit,as they are saying you have 18" rims where as you have 17".
  3. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
    220 seems a strange width. Just stick with 225 as its only 5 mm width and will fit no probs. Most people think the 45 is the profile in mm, its actually a % of the width.
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    25,310
    Poole
    +10,347
    Stick with the current size or they won't fit the wheels correctly.
    If you changed the tyre size you would have to change the wheels to match.
  5. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,021
    Lockerbie, Scotland
    +937
    Thanks guys.
    Keith
  6. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    A sticker somewhere on the car should tell you the tyre pressures relative to the car wheel size.
    I'd stick with OE spec to avoid any handling issues and insurance company get out excuses.
  7. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    its a mistake on the database , you wont find a 220 width tyre ....
