Types of RGB on Barco RCVDS Quad 400
Discussion in 'Projectors, Screens & Video Processors' started by ReTrO, Apr 12, 2001.
Thread Status:
Not open for further replies.
  1. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I have the Barco RCVDS Quad 400 to go with my Barco Data 600. It has an RGB inout card which says it will take RGBS or RGsB, through BNC's.
    Will this take an RGB+S from my Arcam DV88, or is it only high scan rate RGB, like PC stuff?
    Rick
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Rick,
    Pretty sure it'll take RGBS from the Arcam no problem. You'll see there are seperate pots to twiddle for below line doubled sources I think. So if you've only been using a PC you may have to re-do the convergence a bit.
    Gordon
Thread Status:
