Types of file you can save on the HD5?
Discussion in 'Headphones, Earphones & Portable Music' started by foghead, May 22, 2005.
  1. foghead
    foghead
    Ordered my HD5 today and I'd like to know if it can be used as a portable hard drive similar to the ipod. ie, you get the external hard-drive icon and can drag and drop files into it.
    Does the HD5 work in a similar way? - Can I just drop my files onto it and hook it up in work to get them off it?
  2. snownrock
    snownrock
    May 22, 2005
    34
    yes u can
  3. foghead
    foghead
    Thanks...
    The main file-types I'll be transfering are jpegs, word docs etc etc
    Will these go on there and be retreivable on my work PC?
  4. Hasselhoffia
    Hasselhoffia
    Yes definately.
