TX36PD30 Stand / Shelf Size Info Required
Discussion in 'TVs' started by chris l., Nov 1, 2003.
  1. chris l.
    chris l.
    Mar 31, 2002
    270
    +3
    Anyone with a TX36PD30 out there !
    Looking for info on stand dimensions, gap between shelves and shelf sizes. Trying to work out if my centre speaker will fit in top shelf and whether I can get a TIVO and NTL digi box side by side on the bottom shelf ?
    Thanks in advance.
    Chris L.
  2. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    I think it's about 18 or 19 cm...
    Might be wrong as i don't own one myself, just measured in store a few weeks back. Do know it's not enough height for my cente speaker which is 21cm.
  3. blindlemon
    blindlemon
    Both shelves have a useable height of only 17 cm :( Width (at front) of both shelves is 81cm.
    FWIW I have 2 Tivos and I've stood then on their ends behind the stand - kind of angled at 90deg to each other with their front plates pointing forwards. They work fine like this (and run about 4 deg C coooler too!) - and the casework looks like part of the stand from a distance;)
    That leaves loads of space on the shelves :smashin:
  4. chris l.
    chris l.
    Mar 31, 2002
    270
    +3
    Many thanks for the measurments. It looks like my Misison 78c wont go on the top shelf then (need 18cm).
    Ah well off to look for a cheap AV unit (if such a thing exisits).
    Regards,
    Chris
  5. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    From my rather extensive research so far, none seem to - especially if you're trying to find something that has space for a decent sized centre speaker
