TX32PH40 with a purple blotch on the screen....
Discussion in 'TVs' started by Dave_the_B, Jul 7, 2003.
  1. Dave_the_B
    Dave_the_B
    Hello, I'm looking for some advice.
    I bought a Panasonic TX32PH40 two months ago.
    Straight out of the box there was a big purple blotch/bloom on the right of the screen.
    I moved all my speaker's out of the way, switched the set off for a hour, turned it back on but no change.
    I got an engineer out to manually degause it but again no change.
    He noticed it was close to a radiator and suggested moving away from it, again no change.
    I complained rather loudly so they have now replaced the tube :)
    One week later.......purple botch back again:eek: :confused:
    So now I need some advice please....
    The set is in the corner of the room, about two feet away from a radiator and right next to a mains double plug, satellite and external ariel plugs.
    The mains is split useing a surge protected double ganger with the excess of the 2 metre's of cable wound up on the floor.
    All this is within two feet of the back of the set.
    Please can someone tell me if I've made a magnetic hell for myself , if so how can I fix it.
    Many thanks in advance
    Dave
  2. ste1010
    ste1010
    Feb 4, 2003
    512
    Middlesbrough
    +18
    Radiator shouldn't affect it. The coiled cable may, but very much doubt it. What do they want you to do. Place the TV in a cow field so there is nothing to interfere with it.
    Sounds like a duff one to me.
    Ste
