TX32LXD500 or TH37PV500PED - Desperate help needed
Discussion in 'General TV Discussions Forum' started by salfordred, Aug 23, 2005.
  1. salfordred
    salfordred
    Feb 2, 2005
    89
    Gonna buy in the next 2 days..... and I need some final advice.
    Gonna use the following
    Sky+ HD
    XBOX 360
    PC
    DVD recorder
    Can't see anything else soon to attach. Not too worried about size as my room is only 10 foot wide and I think 32" will be enough to be honest.... but 37" may be even better.
    PLEASE HELP SOMEONE.
  2. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Please, can you restrict display questions to the relevent forums - pick one, LCD or Plasma. doesn't matter which unless you are fond of a particular technology and are looking to ask more questions about it than the other. Does that make sense?
    I.e. if you are particularly fond of LCD, but want to make sure you're not overlooking something on the Plasma aspect, then ask it in LCD.
    As a heads up - Panny LCD stops at 32, Plasma begins at 37, so if you haven't settled on a size, your querstion is moot until you do. Then you can go into more detail on whichever you're leaning toward.
