Tx100 screen size??
Discussion in 'Projectors, Screens & Video Processors' started by bonfigli, Mar 19, 2005.
  1. bonfigli
    bonfigli
    Hi there,
    I'm buying a TX100 from Projector point with the 16:9 108.5 x 193cm screen.
    Would I be able to use this screen from a distance of 4m??
    I tried the calculator, but not sure if im using it right :confused:
    Thanking you in advance
    Bonfigli
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    The user manual says that between a max of 3.6 and 4.1 m you can project an image somewhere between 100cm and 112 cm height.
    For 108.5cm it looks like 4m will just about be OK, you may even have some zoom adjustment to spare which is always recommended - best not to use max or min zoom 'cause then you limit your flexibility...PJ
    PS no warranties implied or presumed! :)
  3. bonfigli
    bonfigli
    Thanks for that PJ, just needed conformation that I was reading it right.
    Here goes...... credit card out, no turning back now :)
    Thanks again.
