TX100 Scart to Component??
Discussion in 'Projectors, Screens & Video Processors' started by bonfigli, Mar 25, 2005.
  1. bonfigli
    bonfigli
    Hey guys,
    Still can't believe how good the TX100 is :smashin:
    I've got my Yamaha and and speakers hooked up now (again thanks for the advice)
    I ordered this scart to component cable off the net. The cable is being used between my cable digi box and projector.
    [​IMG]
    My question is, do I use the sync (yellow) cable??
    I was going to plug in the red, green & blue component cable into the projector, and obviously the audio goes to the amp, but do I use the Yellow sync cable for anything??
    Many thanks guys.
    Bonfigli
  2. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    IIRC, you plug the yellow plug into the composite video jack on the TX100. You then need to select SCART RGB in the Tx100 menu, and set your DVD player to ouput RGB!
  3. bonfigli
    bonfigli
    Spot on, thanks mate.
    I didn't realise I had to change the TX menu from component to rgb :smashin:
    Next test, VGA :D
    Bonfigli
